Obscure Chinese DAPs
May 24, 2016 at 2:35 PM Post #1,156 of 8,292
  What is the DAC in the FLANG? Is it the desktop version of the ESS9018?
http://www.flang.cn/1-landing-page/
It's the ESS 9018K2M according to the AliExpress page.
The K2M has only 2 of the 8 DACs inside the chip active, it's the mobile version.
Cheers!
May 24, 2016 at 3:07 PM Post #1,157 of 8,292
  Here is the example of Flang V5 GUI and menus:
Basic, but snappy.
I would much rather have a basic-but-snappy menu system than a fancy-but-laggy menu system.
One of the best DAP menu systems I've ever used (in terms of speed and playlist management, both of which, many DAPs get badly wrong) is the old iPod Classic. Had bloody-awful EQ and utterly horrendous SQ, though
This Flang DAP still has my interest.
May 24, 2016 at 4:27 PM Post #1,158 of 8,292
Picked this up last week from uk Amazon...The  Agptek  Imp. £60.. 16gb., + 64gb micro card £14.... im pleased so far.....
May 24, 2016 at 4:46 PM Post #1,159 of 8,292
Still wondering if a 128 card would work in the Imp.  Nice Shots.  I need a replacement backup for my clip plus that died.
May 24, 2016 at 5:20 PM Post #1,160 of 8,292
........... Its all well and good putting a 128gb card in this player, but irs damn hard enough already to locate stuff....lol....... iv filled the player built in 16gb , and im half way to filling the 64gb card.
Got liads of cds on so far, which i have dragged and dropped from laptop, in w m a .......
If you play all songs....then the plater and card only show 4000 in each folder...... but you can still go to albums and play all..... Player only shows title, etc..... So hard to know who the artist is, ..unless yiu know your music really well, ..:grinning:...
But for the price, im pleased so far..... going to buy another 64gb card when this one gets full...:blush:
May 24, 2016 at 5:22 PM Post #1,161 of 8,292
Note my photo of the. Imp... thus is latest version, with shuffle symbol. Not the previous one with lock button.
May 24, 2016 at 6:11 PM Post #1,162 of 8,292
Placed the order for Flang V5, price is reasonable and my dap fetish out of control.
If all goes well and the product passes my satisfaction level I will be flooding this thread till I am told to make a separate thread.
This is my favourite thread on HF, thanks to this thread I found LPG.
May 25, 2016 at 6:50 AM Post #1,163 of 8,292
[COLOR=000000]according to the AliExpress page.[/COLOR]
[COLOR=000000]The K2M has only 2 of the 8 DACs inside the chip active, it's the mobile version.[/COLOR]
[COLOR=000000]Cheers![/COLOR]
Thank you for the fast response. I was going to buy it, if it were the desktop version.
Still, I like the package and the UI. I am just not sure. I did not like the DX90 so much, which I believe has the same DAC. On the other hand it could also be the DX90s amp section, that may have not be my taste...
Must think about it :)
May 25, 2016 at 10:22 AM Post #1,164 of 8,292
HELP , anyone know what the score is when you have a 64gb card  ( the max the player will read )  and after loading up a fair few cds, then adding a load more cds , the albums have gone onto the card, but the player still only showing the orig amount before adding the rest ?... So what is the point if the max songs the card can be read is  4000.... the same amount being read on the built in memory on player.... ???? ........ Do some players let you add the full amount on the cards and can read them or not ?......... Can't see the point now of buying the larger card, could have used a 16gb  ????
May 25, 2016 at 10:25 AM Post #1,165 of 8,292
what player are you referring to ?
May 25, 2016 at 10:30 AM Post #1,166 of 8,292
The one above in my post,, the  AGPTEK  IMP.... as built in 16gb with upto 4000 songs on, And then says I can use a card upto 64 gb..... but its looking like its same storage on both folders... locking out at 4000 songs , not showing all my other cds ?... only shows them on the card ???... which players let you play more than 4000 songs ?....
Would I have been better to just use a few 16 gb cards ??
May 25, 2016 at 10:34 AM Post #1,167 of 8,292
Might be a DAP set to manual (rather than automatic) indexing; in which case, you might need to invoke indexing, in one of the menus.
Alternatively, you might have a player that is fussy with the way it reads file tags, and the second batch of CDs you ripped might have been tagged differently (or not at all).
But it might just as easily be that neither of the above possibilities are correct - it very much depends on which particular DAP you happen to have.
1) What model of DAP do you have?
2) Have you tried navigating the contents of your memory card using folder-explorer, rather than trying to navigate the contents via 'artist', 'genre', etc. (which are tag-based).
May 25, 2016 at 10:43 AM Post #1,169 of 8,292
Think it is because the max songs allowed on this are  4000 each folder....so its locking out at about 163 cds.... 4000 sogs I expect ?...... iv tried looking over the folders, in all songs, or albums, artists  etc  but still not sowing the other music........ wish id knew this I could have used a few  16gb cards instead..... if im correct then ill get a few.. shame I have to now reload any more cards all  over again...... Which audio play canplay more than 4000 songs ?...... any help thanks in advance... martyn
