Obscure Chinese DAPs
May 6, 2015 at 11:45 AM Post #723 of 8,292
I created a thread for the PAW 5000: http://www.head-fi.org/t/765461/lotoo-paw-5000-shipping-in-may
May 7, 2015 at 3:09 AM Post #724 of 8,292
Aune m2
May 7, 2015 at 8:27 AM Post #725 of 8,292
and here's specs for Aune M2: http://en.auneaudio.com/html/about_aune/news/201_17.html
Aune M2 32BIT DSD portable music player
  M2 is the 2th general portable music player of aune,It co-designed by the M1.B1 ,S18 team.
  M2 general information :
  1)Size:65*110*17--------the same size as B1
  2)2.6''display screen
  3)Using 32BIT flagship chip AK4490 of AKM company , docking perfectly with M2 core asynchronous 32BIT
  4)Gain adjust adapts to headphones and earphones
  5)Designed by the original design team of M1 , with ultra-low distortion OP+BUF headphone amp part
  6)LINE OUT and PHONE OUT output socket
  7)Continous working more than 8 hours
  8)OEM mini size ultra-low jitter  M2 crystal
  9)Asynchronous clock CPLD technology,32BIT playback
  10)With TF card,the maxium support 128G
  11)Support format:
  WAV:16bit|24bit|32BIT- 44.1K/48K/88.2K/96K/176.4K/192K WAV + CUE
  FLAC:16bit|24bit- 44.1K/48K/88.2K/96K/176.4K/192K
  APE:16BIT/44.1K APE + CUE
  DSD format:DSF/DSD64 - DFF/DSD64 ISO
  AAC
  MP4A
  MP3
  This product will released on May ,2015
May 7, 2015 at 8:36 AM Post #726 of 8,292
^ Oh look, they thought adding FLAC support may be useful to people this time round.
Good thinking Aune! Not like their WAV only M1.
Noisy Motel can't even move the M1 at $100 discount.
May 7, 2015 at 9:20 AM Post #727 of 8,292
  11)Support format:
  AAC
  MP4A
  MP3
There is no support for FLAC + CUE ?
May 7, 2015 at 11:36 AM Post #728 of 8,292
I would like to buy it, but must ditch some other stuff first...
The thing with the M1 is, that it has an Cortex M3 processor. It can only do WAV, not more not less. Also anything more than 16bit is a problem...
I love that, but 99% of other people wont consider it. To me its like a PCD player, with more CDs possible...
May 7, 2015 at 4:20 PM Post #731 of 8,292
If I understand you correctly. There are two official DAC boards?
not officially,
chinese diyer sell his dac+amp board usibg the cs4398 chip, and i see on erji.net thet use wm8741 singe and double abd change the original opamp for lpf and headout.
mine using pararel 4xtda1387 with bypass lpf and headphone out..
Regards,
May 7, 2015 at 4:28 PM Post #732 of 8,292
not officially,
Regards,
Very interesting. I read somewhere on the internet, that the M2 is reaching his fifth edition of the prototype PCB, or something along the lines. I believe that it is not far away.
May 7, 2015 at 7:45 PM Post #733 of 8,292
Regards,
where did you get that?
A little bit more details are appreciated
May 7, 2015 at 11:18 PM Post #734 of 8,292
A little bit more details are appreciated;)
m
the battery accidentally stop to work so i replace with the same voltage but higher capacity, the size can't fit the space in aune m1 casing so i put the battery replacement out off the casing.
i replace the battey space with several capacitor to coupling the tda1387 pin 7 to ground since the dac need alot capacitance to get a good bass quantity,i took off all opamp related with lpf and amp, and the power supply for +-9v.
the pararel tda1387 x 4 can drive the 150ohm earbud to about more than equal to 50% volume.
May 9, 2015 at 11:23 AM Post #735 of 8,292
