Obscure Chinese DAPs
May 9, 2015 at 2:23 PM Post #736 of 8,292
where did you get that?
A little bit more details are appreciated;)
m
the battery accidentally stop to work so i replace with the same voltage but higher capacity, the size can't fit the space in aune m1 casing so i put the battery replacement out off the casing.
i replace the battey space with several capacitor to coupling the tda1387 pin 7 to ground since the dac need alot capacitance to get a good bass quantity,i took off all opamp related with lpf and amp, and the power supply for +-9v.
the pararel tda1387 x 4 can drive the 150ohm earbud to about more than equal to 50% volume.
this is why i just bought the m1. A discrete daughter dac amp board. This means that provided you have a solder and basic understanding of circuit boards you cam tailor the sound card to your specifications. Bravo Aune. which means even an idiot like me is able to have a go at diying.
May 9, 2015 at 3:45 PM Post #737 of 8,292
  I keep hearing comparisons between 802 and hifiman's flagship 901, and the universal conclusion is that 802 is a far lesser one, that impression plays unfavorably against 802.
I don't think that's a fair fight, 802 is supposed to be next to 901, that comparison kinda accent where 802 fall behind.
Thanks
why is it not fair? there are a number of people who think that the true flagship was 801, not 802, 901
i don't think player should be judged by company's positioning
May 12, 2015 at 10:35 AM Post #743 of 8,292
  I somehow knew that someone would post something related...
And yet... something made you go ahead and post anyway...
So, who do you have to blame?
May 12, 2015 at 11:32 AM Post #744 of 8,292
The user "audionewbi" postet a pic of the Eros dap and then "rontant" replied with that linkt that leads to ... whatever it is, so not I made the post.
May 12, 2015 at 3:52 PM Post #749 of 8,292
  I wonder what that sounds like when you hold it up to your ears?????
This is headed in the direction of moderator intervention, if it continues, so I respectfully suggest letting the joke drop, now, even though I am not personally offended by it in any way
May 12, 2015 at 10:38 PM Post #750 of 8,292
  I went to Taobao to search for "Eros" but found this instead: http://item.taobao.com/item.htm?spm=a230r.1.14.41.qXXGr0&id=43942575731&ns=1&abbucket=7#detail
well ero---> ero _ _ _ ----> エロ(エロチシズム) in japanese
I'm sure everyone can resist and not to search about it >: D
nomenclature nowadays..... ( good job manufacturer!)
