Can Someone compare (my) fiio m3pro with jwd jwm115 (best under 100dollars budget dap competitors)
Obscure Chinese DAPs
- Thread starter pekingduck
How your IHIFI100? In spec is awesome for the price. I searched this amp today before read this topic and my first reaction was: this is not as portable as I need. I have station HiEnd Nelson Pass DIY Amplifier using JFETs without negative back loop and build from top tier components.Ordered a Xuelin IHIFI100 amp and resisted the GAD dap.
I ordered ZiShan's GAD DAIII OCL Amp for same size combo with ZiShan DSDs Dual AK4497.
Barndoor
Still waiting for delivery of my Xuelin.How your IHIFI100? In spec is awesome for the price. I searched this amp today before read this topic and my first reaction was: this is not as portable as I need. I have station HiEnd Nelson Pass DIY Amplifier using JFETs without negative back loop and build from top tier components.
Let us know how you get on with the GAD.
I have a question, see if you can help me, please.
I have several Dongles (Earmen Sparrow, Sonata HD Pro, Sonata BHD) and I like to use them with players. The Tempotec V1-A works very well with them, but the battery life is short.
Do you know of any other DAPS that can be used for transport, with a higher battery capacity, in that price range?
Thanks in advance.
Thanks in advance.
Barndoor
Have you considered using a USB splitter and battery pack to supply the dongle rather than using the source device's battery?I have a question, see if you can help me, please.
Thanks in advance.
Ummm, it could be an alternative. I guess it must be easy to find a USB cable that splits the data signal, from the power signal. Or do you think you can use any USB hub with a charging input?Have you considered using a USB splitter and battery pack to supply the dongle rather than using the source device's battery?
Batteries are more common to find and I think I have some.
The set would no longer be more or less portable, but it could work.
Thanks for the advice.
Sluggist
So i have been looking at zishan dsds (the one's with dual ak4497 or single ak4499... Personally just wanted to try the ak4497 or ak4499 and I think they could be used as dacs.. BUT I don't really need another DAP....
are there amp/dacs out there that have the AK4497 or AK4499?
unifutomaki
are there amp/dacs out there thAT HAVE THE AK4497 or AK4499?
Yinlumei M400
Aenlandril
Is there anything better than the FAudio FA3 I should be looking at instead?
I want physical buttons and album art, a line out would be nice too
@Aenlandril If you want good nice looking system interface take a look for a known popular brands. Fiio, Shanling, xDuoo, FAudio and you will got what you pay.
HiBy R3 Pro or HiBy R3 Pro SaberIs there anything better than the FAudio FA3 I should be looking at instead?
gimmeshelter
What's a good android DAP for under $250, I'm looking for something I can listen to my Qobuz account on with ability to download also?
Blazer39
- Apr 30, 2015
Dear members!Unfortunately i dont have the budget for hiby r3 pro saber.So I am considering to buy a shanling q1 or a hiby r2.Mainly i listen to tidal, and some flac music. So will be better sound on r2 with direct stream, or q1 can handle it via BT with my phone. Can You please help to choose? Is the sound quality from q1 so much better on flac music that i should give up direct tidal stream from r2? That will be my first dap. Thank you
when it comes to budget DAPs i think shanling is better, there is a reason why m0 was so popular..
if your willing to pay 300$ then get hiby r5, otherwise shanling Q1 or m0 are good players.
Themilkman46290
Any extreme deals? I haven't bought anything this 11.11, none of the deals seemed that awesome, shipping is atleast 3 months, but was wondering if I missed anything
Total: 32 (members: 4, guests: 28)
