Guys, I’ve been out of the DAP scene for a while. Still using my trusty xduoo X3 with Rockbox.
I’m ready to move on.
What are some good options nowadays? I’ve been out of the budget ChiFi DAP game for a few years. The last I checked in, the Benjie T6 was recommended as a good bang for buck player.
Ideally, I’d like it to have:
- line out (for use with FiiO amp)
- touch screen preferred, but not required
- no laggy buggy firmware, no goofy 2 second delays or clicks or static between songs, etc
- ability to set my own EQ (not preset junk like “pop”, “rock”, “jazz”, etc
Optional but would be a definite plus:
- Bluetooth 5.0, but I’d settle for 4.2
- AptX or AAC support
- balanced port
I don’t need DAC.
I guess another option could just be an ES100 adapter plus my iPhone, although that doesn’t help with with flac. Apple is about to discontinue iOS 13 from the iPhone SE, so I might relegate my 128GB SE to duty as a dedicated DAP since it has a headphone jack and the sound is pretty clean. Can also do Tidal among other streaming apps. And I wouldn’t have to spend a penny.
Otherwise, the DAP budget would be $200 up to maybe $300.
Some players I’ve considered, but don’t know much about:
Hiby R3
Hidiz AP-60 II
Hidiz AP-80
Aigo Z6 Pro
Cayin N3
Shanling M0
Shanling M2X
Cayin N5IIS and Shanling M5S look totally badass specs, and the Cayin has dual card slots which is a definite plus. So I could keep saving my pennies for that if it’s totally worth the extra price.
Also, as comical as the Zishan DSD Pro looks in 2019, it has nice specs for the price. And coming from an xduoo X3, I’m used to button-only navigation. So I could certainly consider the DSD Pro if it is the best bang for the buck option.
