Oblivion | UltraSonic Studios
Oct 1, 2022 at 8:23 AM Post #6,511 of 7,528
Oct 1, 2022 at 8:25 AM Post #6,512 of 7,528
@Isaacc7
I usually don't post pics mid build but thought I'd make an exception here. Mainly to show Isaac of course.
This is the push pull version of Odyssey with manual grid bias. The four output sockets are in the back row and driver tubes at the front. Below each output tube socket you have a trimmer to adjust the negative grid voltage. The red measuring terminals is for external voltmeter to read that voltage. There's only one black terminal as it's just ground anyway.
In between each pair of output tubes there's a little toggle switch. Toggle to the left to measure the anode current of the left tube on the mA meter and toggle to the right to see the anode current of the right tube on the meter.
In the middle there's a panel voltmeter and below it is a trimmer. Here you adjust the B+ (also anode voltage). The range will be around 240V-400V.
The two large toggle switches are for the heaters. Up is 6.3V and down is 12.6V. One switch for driver tube sockets and one for output tube sockets.
Isaac, do you need me to label everything or can I leave it as is? I think the "clean" look would get destroyed as there would be lots of labels lol :)
Btw, this is the heaviest amp I've built to date! That Monolith PT is a beast! The amp weighs 26.5kg as it is now even without bottom cover and lots of components missing!
Killer build sir!
Oct 1, 2022 at 10:03 AM Post #6,513 of 7,528
You mean there's more than Oblivion there?
Yep - There are 5 Oblivions and 1 Telemachus in Indonesia so far in 2022. The 1 Telly owner is me.
By 2023 There should be 2 more Oblivions and 2 more Tellies coming, making the total to 7 Oblivions and 3 Tellies. There is possibly 1 more additional telly but he has not fully decided yet.
Also I've tried the 5th oblivion today, the one that looks like a citadel. The performance is sublime as expected.
Oct 1, 2022 at 10:07 AM Post #6,514 of 7,528
@Isaacc7
Looking awesome as always Tomas, looks like a beast, especially with those really beefy Transformers :beyersmile:
Oct 1, 2022 at 2:02 PM Post #6,516 of 7,528
Oct 1, 2022 at 3:05 PM Post #6,517 of 7,528
Wow that's news to me. There's love for Oblivion and Telemachus there. There should be a Odyssey there to complete the picture.
Oct 1, 2022 at 3:24 PM Post #6,519 of 7,528
@Isaacc7
Woo! Love the look! No need for labels, let’s keep it clean. Those are banana ports for reading the voltage right? Those monolithic Magnetics transformers are looking rather like monoliths Lol. Triliths? What does the back look like? That power transformer is big enough it could make sense to have it on a separate chassis. I prefer it all on one though. My preamp has separate chassis for the power supply and it’s a bit of a pain and I’m always worried about the proprietary umbilical cord failing me. You’re further along than I thought you’d be, it’s on the the first of the month!
Oct 1, 2022 at 3:30 PM Post #6,520 of 7,528
What I want is to be able to use electrically unmatched combos on output and have the same precision as in the manual grid bias. I need fast and precise amps because of my musical preferences, and you are able to do them. I would like to have a Citadel, fully balanced, with manual adjustable output grid bias so I can use a quad of GEC E3375 or GEC ATS25. I have a big collection of outputs but not all of them are electrically matched. I want to use in this Citaldel EL34, ATS25 or E3375 quads.
Yeah, that’s my situation too. When you love vintage tubes you usually can’t get matched sets.
Oct 1, 2022 at 3:37 PM Post #6,521 of 7,528
@Isaacc7 is a very experienced customer and he knows exactly what he wants. This is my most expected build because I am fully convinced that he will use it finding a lot of new tube combos. Since all UltraSonic amps have the same pedigree I wait for his amp like "air". I know that this will help me level a lot.
Good luck @Isaacc7 , looks stunning.
Yeah, this is kind of a love letter to tube rolling lol. I fully anticipate this being my last push pull amp.
Oct 1, 2022 at 3:40 PM Post #6,522 of 7,528
It's a love letter to tube rolling and a suicide letter to your wallet. But you are lucky to use mostly unknown types and this will help you a lot. I will definitely go to the 12.6V path on my next amplifier.
Oct 1, 2022 at 3:45 PM Post #6,523 of 7,528
What is the rated power for this amp?
The OT transformers are rated at 30watts down to something ridiculous like 5hz. In theory they could do a lot more at normal musical frequencies. In the end, the power supply will limit the maximum power. Well, that and my ears lol. While I expect to be able to get something like 30 watts from GU50, KT88 and the like. In reality I really only need a handful of watts And so will never need that much. On the other hand, maybe now I’ll finally have enough power to get a pair of LS3/5A monitors with their 83db sensitivity…
Oct 1, 2022 at 3:53 PM Post #6,524 of 7,528
Yeah, no one has dared to take the plunge for the Odyssey. The oblivion and telly are getting most interest as someone made the first order for everyone else to demo.
Oct 1, 2022 at 3:54 PM Post #6,525 of 7,528
Luckily(?!) I feel like I’m putting the final touches on my tube collection. And yeah, I have spent an unconscionable amount of money on them. I have so many now… Luckily for me I am addicted to relatively inexpensive tubes, or at least less expensive versions of expensive ones lol. I’m just putting the finishing touches on Mullard, Brimar and Fivre 12sl7 order. These tubes are a prime example of ones I wouldn’t spend the money on the 6v versions.
I’m also looking forward to trying some lesser known tubes like 6/12av5 and just learned that I can use 2e26 in triode on this amp! What’s a few more adapters lol.
