@Isaacc7
I usually don't post pics mid build but thought I'd make an exception here. Mainly to show Isaac of course.
This is the push pull version of Odyssey with manual grid bias. The four output sockets are in the back row and driver tubes at the front. Below each output tube socket you have a trimmer to adjust the negative grid voltage. The red measuring terminals is for external voltmeter to read that voltage. There's only one black terminal as it's just ground anyway.
In between each pair of output tubes there's a little toggle switch. Toggle to the left to measure the anode current of the left tube on the mA meter and toggle to the right to see the anode current of the right tube on the meter.
In the middle there's a panel voltmeter and below it is a trimmer. Here you adjust the B+ (also anode voltage). The range will be around 240V-400V.
The two large toggle switches are for the heaters. Up is 6.3V and down is 12.6V. One switch for driver tube sockets and one for output tube sockets.
Isaac, do you need me to label everything or can I leave it as is? I think the "clean" look would get destroyed as there would be lots of labels lol
Btw, this is the heaviest amp I've built to date! That Monolith PT is a beast! The amp weighs 26.5kg as it is now even without bottom cover and lots of components missing!
