mikeaj
- Jan 10, 2010
Running the signal through an amp twice will reduce the clarity of the sound. Imperfect analogy, but think of talking to someone through a cell phone that doesn't have a person on the other end but is simply the voice from another cell phone with a person on that end! The quality is going to get worse the number of cell phones are in the chain. Similar with amping. Double amping is reduplicating the effort without any gain...except loudness (provided your lamp isn't loud enough). Why not amp through 3 or 4 amps? The sound just gets degraded the more times it is amped.
Well yeah, it depends on the products involved, but with modern electronics, high-fidelity amplifiers driving an easy load (another amplifier at some thousands of ohms input impedance) shouldn't really have trouble and degrade the sound by any substantial amount. The effect of the last amp driving the headphones should dominate all the others, by far, particularly for lower-impedance headphones. Of course you want to avoid it if you can, but the point, as I said earlier, was that it's usually not a big deal. In many cases the difference is probably trivial enough to not be audible, unless the noise floor get raised high enough.
Actually here we're just talking about some kind of output stage buffer to drive headphones—except actually I don't think the Juli@ has one?
See here that after double amping, performance improves significantly, because the second amp is better than the first one (the one integrated in the sound card):
http://www.head-fi.org/t/568705/review-nwavguys-o2-diy-amplifier/1080#post_8150435
