castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
Tip for those who find the ODAC a bit thin in the mids. Don't upsample your ODAC to 24-bit/96Khz on Windows, instead go for 24-bit/44.1Khz if you're listening to CD quality material. Mids gain a hint of warmth and become more liquid, though at the expense of a smaller soundstage. Try it.
This tip is applicable to all DACs! Here's a set of measurements of a PCM5102A DAC to back you up. The ES9023 in ODAC performs the same.
Win7 set to 24/96k, streaming a 24/96k sine wave at 10kHz (no up-sampling):
Win7 set to 24/96k, streaming a 24/44.1k sine wave at 10kHz (up-sampled):
Check out that noise!
do you happen to have the same test done with16/44 and then 24/44 as the output setting, but using 16/44 files?
I was just asked if 24/44 was a "real value". my buddy might no be alone thinking "but it's wrong, the output is 24/44 and the track is 16/44!"
thank you for this one anyway it's good to have.
