It was a surprise when I first noticed the measurements. After checking different units and DAC models, and conferring with other engineers, it was clear that full scale DAC performance is rarely discussed.
THD+N performance is 2-3x better for input just below 0dB. Keep in mind you're rarely going to hit 0dB peaks when listening to music. Even today's
heavy handed recordings will only hit 0dB peaks for a few seconds throughout an entire track. And even if you do listen to a track full of 0dB peaks, 100% digital volume may yield THD+N of 0.0070% at peaks through ODAC (worst case), versus ~0.0025% at slightly reduced digital volume. It takes focused, well trained ears to detect this difference. We expect transparency at THD+N below ~0.005%. It's a rather small audible difference, yet objectively/measurably obvious.
We include a short blurb in the
Listening Tips of JDS Labs instruction Guides:
Zorrofox is correct. Digital volume control is fine to use aggressively as long as the DAC has excellent dynamic range.
