adydula
- Dec 14, 2010
The O2 is not totally perfect, even though I am a ardent user of 2 of them plus an improved ODA of AGDR's design.
Recently a person reported frying a NJM4556A chip using a set of HE400's.
The cans used were 35 ohms and have a sensitivity of 92.5 db/mW. (HE400's).
You can easily go way over the maximum output dissipation for the NJM4556A chips in the upper volume levels of musical peaks. Headphones like that need an ODA type of amp. So it is quite possible to go 100% or more of the maximum allowed package dissipation for certain combinations of low impedance low sensitivity headphones AND higher volume levels AND specific music that has high or sustained peaks.
The maximum power dissipation for the NJM4556A chip's DIP8 package is listed as 700mW on the datasheet here:
http://www.cn.njr.com/PDF/NJM4556A_E.pdf
But that is at room temperature and the insides of the O2 will get warm with those output chips dissipating and the voltage regulator heat. So de-rate that to 600mW.
Then the chip quiescent current is listed as 8mA to 12mA. The higher current end will usually happen at higher output levels. So be conservative and say 11mA, with the O2 on AC power that gives (12 * 2 * 0.011A) = 264mW. Just like that the quiescent current has used up about half the available chip power dissipation just sitting there at idle: 600mW - 264mW = 336mW left for headphones on each NJM4556A chip.
Using 120dB as the maximum level (musical peaks) in the headphone spreadsheet. But at just 112dB the HE400 needs 1.76Vrms and 50mA. So that is 12V - 1.76V across the chip, or 10.24V. The power dissipation for both chips halves then (in the same NJM455A package) is 10.24V * 0.05A = 512mW, which is 35% over the 336mW maximum chip power dissipation from above. At 115dB the power dissipation is 100% over limit at 660mW. That is more than enough to cause the chip to explode in half like that.
Working with the numbers the maximum loudness level to hit the 336mW of available package dissipation would be 107.5dB.
So this person would need to listen to his headphones at lower levels and/or get a higher current amp like the ODA to keep that from happening.
The O2 is not safe from internal chip damage for any 16 ohm and up headphone.
This recent event occurred with a commercially purchased O2.
FYI
Alex
Note the technical details come from a very highly qualified EE.
FYI
Alex
