Hi all.
Kinda jumping into this thread feet first with a fairly specific question. Apologies in advanced if this has already been discussed somewhere before.
I have the Fidelio X1s and I use them pretty extensively off the headphone-out of my Marantz AVR (SR6005) with Dolby Headphone. The X1s are known to have somewhat uncontrolled bass, but I feel it is more pronounced on my AVR. The Marantz doesn't have a dedicated headphone amp, but rather the signal from the left and right speaker amps is attenuated by a resistor. I've never been able to find the output impedance of the headphone-out, but I was told the output voltage is 1V @ 16 Ohms, 2V @ 32 Ohms. I suspect this high voltage, and probably not much damping, is the cause for the bass bloat.
Currently, I just EQ the bass to -2 dB to help take some of the edge off. However, I've been pondering double-amping the DH processed signal through an O2 amp to hopefully better control the bass and not have to resort to taking some of it away.
I have two questions regarding going this route:
Thanks!
- Would I be fine with the stock gain of 2.5x / 6.5x or would I be better served with 1.0x / 3.5x? I know the X1s are easy to drive and want to make sure I have enough play on the pot.
- What would be a recommended volume to set the AVR at? The headphone-out is of course variable and can go from –80.5 dB to 18 dB. I normally listen around -28 db.
Thanks!
