Several updates on the ODA amp from AGDR at DIYAUDIO.COM....
He has sent the ODA to Mike G and Mike has done measurements that are posted here and at DIY Audio. Mike also hooked up the ODA and played his 15" Alec's with the ODA....amazing etc.
AGDR is working on some THD measurements and has received the ODA back from Mike G and has modified it and will be sending it back for round two... of testing.
Mike has possibly discovered a THD issue with the original O2 with the volume pot being at mid way etc..AGDR has been analyzing this and thinks he knows what the issue might be. Its still below audible hearing etch.
You can read the techie stuff again over at DIY Audio.
That said none of this affects the sonic equality at all but AGDR being a perfectionist has continued to make improvements to the ODA. None of them really would be audible but makes the ODA better, safer from line input transients and more easy to build. So the latest V2.1 boards are going to be sent out shortly after he gets parts from Mouser. The 2.1 can be seen in this thread above and photos.
Details on the 2.1 revisions are listed in great detail on agar's Google drive under the 2.1 area.
I will be updating my 2.0 ODA with a few of the component updates, one being a transport across the AC power inputs to help with any surges, two regulator capacitors from 10uf to 22uf..based on data sheet errata, no sonic issue here, just one of a corner case oscillation possibility.... and a Pico amp fuse in series with one of the ac line inputs.
Also the big news is that agar asked me to share he will be offering ODA BOARDS with the small hard to solder SMD parts' Here is his post:
"In other news I have decided to sell ODA boards with just the SMD stuff soldered on for an additional $39 labor fee plus the $32 or so worth of SMD parts. All as time permits, lol, which will probably mean weekends, just doing them as ordered. If you run into anyone in your travels wanting a through-hole only ODA, feel free to point them to the posting:"
You can send AGDR a pm directly and/or read the post at diyaudio in the vendor area.
Alex
