Noble Katana vs Rhapsodio Galaxy
- Both are neutral reference type IEMs. But both sound very different than similar. One of the reasons is that Galaxy is a single Dynamic Driver IEM, while the Noble is 9 x BA driver IEM.
- Galaxy is a smidge better in terms of technical capabilities such as resolution, transparency, details retrieval and imaging. These are some of the strengths of the Galaxy .
- Both have excellent speed, PRaT and dynamics. But Galaxy has better ADSR for the most part, and but not by a huge margin.
- Katana provides a better sense of soundstage space with good amount of width, depth and height. Galaxy is wide but lacks depth and height. Katana’s presentation is also more airy, compared to the presentation of the Galaxy. Separation is on the same level, but the depth in the soundstage helps with better layering on the Katana.
- Tonal balance is one of the flaws of the Galaxy. It has amazing bass and bright treble and between these 2 sits the humble mids, which sometimes come off as a slight ‘U’ shaped tuning. Katana has better tonal balance throughout its frequency.
- Bass is slightly north of neutral on both IEMs. Galaxy with its DD has an authoritative bass with excellent decay. Katana’s bass is quick, sharp and clean.
- Galaxy’s mids are not so full-bodied and placed slightly behind. The mids on the Katana is neutral with lush body and neutral placement (may be just a hair front of neutral that works as an advantage for vocals).
- The treble can be a matter of choice. Both have bright, airy, sparkly treble. Katana’s treble is lighter while Galaxy’s treble is slightly brighter and has more weight.
- Because of the bright treble and high level of transparency and resolution, Galaxy is not so forgiving and can get harsh. Katana in comparison is bit more relaxed.
- Galaxy also requires a powerful source to be driven well. Katana plays just fine even out of a smartphone.
- Galaxy is the best at many aspects but, does not do so well in some aspects. It is like out of ten aspects, it scores A+ or A in 7 aspects and a B or B- in the remaining 3 aspects. While Katana has consistency with an A or A- in all 10 aspects.
- Because of this, Katana is an easy recommendation. But, if what you are after is something, that is listed in the Galaxy’s strengths or Dynamic Driver bass, it’s hard to beat the Galaxy.
