Mojo777
- Jan 28, 2007
Thanks raypin. Helpful reply.
Mm..if you can wait, Noble has an annual Black Friday/Cyber Monday sale. Last November, it was 15% off plus a free Noble BTS for Ķatana or Encore purchase. Also, last June Noble discount was 20% off (44th Bday of Wizard). Not sure about audio shows.
Thank you for your reply. November is too far away, but June would be okay, especially with a $400 savings.
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
What is the Sensitivity and Impedance rating of the Katana?
Just made a big upgrade from the Shure SE535 to the Katana. Very excited, although I am a little worried how they will fit compared to the 535, which are very comfortable. I hear the Katanas pair very well with Chord Mojo.
I have Shure 846s and can confirm Katana is a good choice for Mojo![]()
I didn't own them at the same time but I was surprised to find that the Katana is significantly more comfortable than the SavannaThe Savanna seemed to have a deeper insertion and I could only tolerate them with the smallest tips. I never forgot I was wearing them either. The Katana, on the other hand, seems to have a more shallow insertion depth. I can use medium tips comfortably. I almost immediately forget I have them in. Strange because I thought the Katana had the same dimensions as the Classic line. My assumptions almost kept me from buying the Katana. I'm happy I went out on a limb! The best I've yet heard!![]()
Those are interesting findings, the CAD work on the Katana and the Gen 2 classic line is essentially the same. Gen 1 classic line is different from the Katana
