procreate
- Oct 28, 2006
Miguel, if I may, and please correct me if I'm misinterpreting what you wrote.
Kabeer, Miguel has given you the answer specific to his listening habits. Simply said, at the volume that he uses (iPod volume at about 60% to 70%), the amp has enough reserve to drive a full-size can with authority (allows transients to be played to the fullest).
If you listen at higher volumes, it might not have those reserves.
Originally Posted by mrarroyo /img/forum/go_quote.gif Now there is a difference between driving and truly making a can shine. When I use my K701 with an amp I listen to the same overall sound pressure level as if it was driven straight out of an unmodde ipod. That is with the iPod volume at about 60% to 70%. However with the amp even though the overall volume is the same having the power reserves of the amp it allows transients to be played to the fullest instead of cutting off some of the wave due to clipping from the iPod amp. |
Originally Posted by Kabeer /img/forum/go_quote.gif You have said the supermicro IV can drive demanding full size cans to high volumes, but in your opinion do you feel it can drive them to "sing", or quite close to those full size amps you mentioned before? |
