psikey
- Jul 15, 2008
Got to say the left channel wifi interference on sensitive IEMs is getting more annoying.. this player is a troublesome little rascal..
I could ship it from Amazon US where it shows $9 but with delivery & Tax/Duty comes at £19!
That wont make any difference to the sound lol
Under the payment section "visa, master...", You can find a variety of adapter section, simply click the ">" on the right to enter. Its written in Chinese only.i cant seem to find this item on the link it just gives a loading page ,any particular name on this product ..i like the right angle nature of this
I'm already sorted with my 4.4mm/3.5mm versionYou need 4.4 right?
The only way you'd notice any difference is if the resistance on the new cable had less resistance. Possible but highly unlikely- maybe if you went from copper to solid silver $$$.
I can't make it look as pretty as you guys have but I believe mine is not affected by the bass concern
I think I've done this right:
I've got a UK Sony Walkman in blue, bought from amazon.co.uk
This looks like no signal, just noise. Did you connect to a line-in? A headset combo jack will not work.
If you don't see an input signal here, it's not working:
There was an input signal - although not as high as yours. Yes, I only have a laptop - no desktop available for me.
So if a combo jack won't work, can I use one of there instead?
Then I'll just connect the A306's 3.5mm to the Mic input.
The combo jack (TRRS female) won't work because the mono mic input is shorted to ground when using a normal 3.5 mm TRS (male) cable.
The pink mic-in jack "might" work, but I have not tried it myself (my computer has a normal line-in (blue jack)). Perhaps someone else can chime in that has tried.
Got it. Thanks! Will give this external soundcard a go.
