New Sony Walkman NW-A300 Series (Android 12)
Mar 8, 2023 at 5:01 AM Post #1,816 of 4,139
when i'm using the sony as a usb dac from my pc to speakers (that have their own volume slider), what volume level do you recommend i put the walkman on? full?
at the moment i have the walkman on full, the windows volume slider on full, and them i'm using the speakers volume wheel to control volume
cheers
Mar 8, 2023 at 5:04 AM Post #1,817 of 4,139
For anyone looking for a case, the CKS-NWA100 case for the A105 fits really well. Might be easier getting hold of one of these than the A306 one.
Mar 8, 2023 at 5:13 AM Post #1,818 of 4,139
Just grab a 3.5bal to 4.4bal adapter from Taobao. I have 2 similar cables, one in 3.5, another in 4.4 so that I can use to compare. With using the adapter, I immediately notice wider soundstage and harder bass. Sounds overall becomes cleaner and darker, maybe a little bit louder and a little bit more details(!?) Funny thing is the interfere noise from wifi seems to go away too.
Mind sharing the link? Looking for this type of adapter as well.
Mar 8, 2023 at 5:41 AM Post #1,821 of 4,139
Mar 8, 2023 at 5:45 AM Post #1,822 of 4,139
Mar 8, 2023 at 5:56 AM Post #1,823 of 4,139
Mar 8, 2023 at 6:08 AM Post #1,824 of 4,139
Mar 8, 2023 at 6:09 AM Post #1,825 of 4,139
Mar 8, 2023 at 6:13 AM Post #1,826 of 4,139
Mar 8, 2023 at 6:17 AM Post #1,829 of 4,139
Won't work with any of these - we need a 4.4mm Female to 4 pole 3.5mm Male.
Did you not like the cabled version I linked to on Amazon UK? There are some others.
One I'm using https://www.amazon.co.uk/dp/B081CHRPHT?psc=1&ref=ppx_yo2ov_dt_b_product_details Only £11.90 and works fine.
Looks promising. But any chance that you have verified the pin outs for this? If this was made with Hifiman 4pole balance in mind - then the pin outs would be different.
Mar 8, 2023 at 6:18 AM Post #1,830 of 4,139
Got to say the left channel wifi interference on sensitive IEMs is getting more annoying.. this player is a troublesome little rascal..
