Synergist969
I hate to interfere with this discussion on the topic of hearing sensation and perception/psycho-acoustics, etc., However, I would like to request input on a functional question/topic...
(I had already attempted to solicit input to my inquiry in a couple of other related threads, however received rather minimal response, hence my resumission in this one...So...In order to determine if my speaker choice is appropriate for Ragnarok...?...
I currently own both the Ragnarok and Yggdrasil, and a couple of months ago elected to replace my venerable Audio Research LS3 solid-state pre-amp with the "Rag", due to the LS3 continuing to generate a low level 60 Hz. buzz...so that the "Rag" is feeding an Aragon 4004 amp...
Firstly, the "Rag" clearly generated more bass energy than the LS3...(I had to lower my pair of SVS sub's output by 5 or 6 dB's to regain a good balance, (crossed over with my Lipinski Sound L-7 monitors at 60 Hz.))...
Secondly, I believe that the sound-stage was not adversely affected by the "Rag" replacement of the LS3, though perhaps a touch less "air" possibly due to the more "bassy" quality of the "Rag"...Oh, and in conjunction with the "Yggy", the imaging,(depth, breadth, image specificity, air, etc.), is in a wholly new league relative to using the older Bifrost...
So, I have been considering a separate set of speakers to use with the "Rag's" speaker outputs, and have considered several, including the KEF LS50's, the mini-maggie's and/or the maggie .7's, however, due to space and or power concerns, have elected to pull the trigger on a pair of the new, Version 2, Audience Clairaudient 1+1 speakers, a crossover-less, bipolar design, mini-monitor...which, based on professional reviews, generates exemplary clean and flat mid-range & highs, electrostatic-like driver speed/response time, and world-class detail,imaging and sound-stage...I hope to get the best of many worlds, including the bi-polar generated increased depth,(would have obtained the same with maggie's di-polar design, but concerned with efficiency and/or space requirements for the sub-panel), along with the pristine signal quality allowed by crossover-less, single driver design, in a small package that will ultimately mate well with a pair of high quality, "fast" subs...
I am wondering if anyone has tried the "Rag" with the "1+1's", rated at 87dB., or perhaps even the "The One's"...by Audience? How about experiences with alternative speakers?
Thank you for your input...
