So there should be at least 50 yggdrasils at past the 165 hr mark by now. Where are all the reports on the final change? Other than post 6802 by
@negura which I somehow missed skimming to catch up. Thank-you everyone for pointing me back to that post. And those describing the tonal changes prior to 165 hrs which may not reflect the final sound after the recommended warm-up.
Ok, I'll give my less than capable prose here.
The change is real in my opinion. I would not have believed it, but I now have heard it with my own ears. I have had an Auralic Vega and Violectric V800 powered up similarly for A/B/C comparison. Level matching is within 0.3 dB for the Vega and Yggdrasil. The V800 is approximately 3 dB lower given the maximum output voltage available. All three feed an Eddie Current ZanaDuex SE. Headphones used for this round of comparisons are HD800 and TH900.
All along I have felt the yggdrasil is a very capable, competent DAC and have no regrets adding it to my lab inventory. Tonight I pulled out a great example of what the yggdrasil can deliver. Some of you may remember the Emerson Lake & Palmer album which had on it Lucky Man. Well that album also contained a song called Tank. At 4:05 to 4:15 in that album is the crescendo of the drum solo which ends in a synthesized drum sound and a rather large, low frequency event. On vinyl, with a good system, this resulted in a pant shaking experience. Years ago when I acquired the CD and of course listened for "The Event" on my good system of the time, I was rather disappointed. I even cursed the CD transfer engineering, complaining loudly to my wife how they had turned the sound into a dull pounding of cardboard. Ok so here we are many years later. My first inclination that maybe it wasn't the transfer (and the transfer engineers vindicated) but deficiencies in my playback converter (DAC) was brought to life by hearing the Vega. Most of the impact seemed to be intact through the Vega, which scored many points with me for that experience. But after the warm-up time, the Yggdrasil recreated that Very Low Frequency event, even through my HD800 such that I feel the power in my head as a LF vibration, not quite as a sound. The VLF is not present with the Vega. Ok Yggdrasil, I'm impressed. As I audition more CD transfers to the digital library, the experience appears to be repeating in a rediscovery of music rather than recording.
I am now hearing a greater immediacy, sharper transient sounds, better low level details, space between instruments, space between notes, than before. Greater clarity. I could go on, and probably have done so too much. Let's just say that usually it takes a couple of glasses of wine to smooth out the details to a pleasant experience for an evening of listening. The system upon which I am listening does so without any libations.
So go hear this for yourself at a headphone meet if you can. Make sure the person bringing the yggdrasil to the meet has kept it powered on with a UPS so you are hearing a fully warmed up unit.
