jexby
- May 29, 2013
I never ran into that problem when I was using my Gungnir with various versions of Audirvana and OSX.
Now using Audirvana Plus 2.09 with Mavericks with my Yggy, still with no problems.
FYI: I am running in iTunes Integrated Mode with Exclusive Access and Direct Modes engaged. Integer Mode is off. With no upsampling. Volume Control set to DAC only, Max level 100%. Use AU effects off.
just matched your settings with my Audirvana 2.0.12 and OS X 10.10.3 - and the bass clipping is still there via Gungnir and Lyr 2.
note: I even tried Audirvana in Integrated Mode. same issue.
and later switched the Converter to "Core Audio" - clipping still happened.
downgraded to Audirvana 1.5.10 and used iTunes Integrated mode - clipping still happened.
if I play the same track(s) in iTunes (not Audirvana) - the clipping does NOT occur.
beginning to think it's just a "hot" mastered track + Audirvana putting it over the edge....
