Originally Posted by nickknutson /img/forum/go_quote.gif
Vinnie,
Have you heard anything about the iTank iMod cases?
Hi Nick,
I am still waiting to hear pricing info for the iMod iTank cases. I'm not sure if I am going to go forward with custom iMod iTank cases, but they are definitely going forward with 4G iTank cases (which can be used for the 4th gen iMods and they will be available in black or aluminum finish) and the 5G iTanks are already available.
YoungClayB... thanks for posting your response from YoTank.
Originally Posted by cpk /img/forum/go_quote.gif
Vinnie how is the 5g sounding now? Inquiring mind need to know.
Thanks
Hi cpk,
It is sounding incredibly good! I'll be doing some more A/B later tonight with the 4G/5G iMod.
Originally Posted by aluren /img/forum/go_quote.gif
so the headphone out of the 5G imod is preserved. what happens when i adjust the volume through the headphon out? and what happens if i use the ALO imod cable? will i be able to adjust the volume through the ipod if the dock is attached?
Hi Aluren,
Yes, the headphone out of the 5G iMod is preserved and NOT modded... it is completely independent of the actual iMod, which now exits from the dock connector. When you adjust the volume of the headphone output, it has NO influence on the modded line out. The modded line out is a line out, so you will NOT be able to adjust the volume.
Originally Posted by theory_87 /img/forum/go_quote.gif
Will it be made for the 4th Gen imod too?
Will you consider 1 Gen Nano since you did 1 before?
This is a nice idea. One will need it during burn in period.
Hi Theory_87,
Yes, the same iMod tags can be also applied to the 4th gen iMods.
I will consider modding both 1st and 2nd gen Nanos, but I will not have time to look into this until after the 5G/5.5G iMods are moving along, as these are priority for me.
Originally Posted by vYu223 /img/forum/go_quote.gif
Sorry if this has been asked before, but-
Will Vinnie be considering to also put the line-out at the dock for the 4g iPods? It would be great to be able to preserve the headphone out, so that the DAP may be used unamped when necessary (like the 5g iMod).
Hi vYu223,
I have not decided for sure, but I am probably won't offer this option with the 4th gen iMods. This will only apply to the 5th gen iMod.
Best regards,
Vinnie
