Posted in the 650 thread:
I'd been holding off a bit on really commenting on the HD-650 with the Bryston BHA-1 amp. I purchased the BHA-1 from a fellow Head-Fi'er via CAM because I'd heard good things about it, and wanted to try another SS amp (the Gustard H-10 was too warm with the 650's for my taste), and wanted to try going fully balanced from the Teac-UD-501 DAC to an amp and to the headphones.
I few cables later I was able to try this out, so here's some (scattered) thoughts:
- the BHA-1 is a brighter amp than the H-10 with great detail and quite neutral signature
- the SE output on it uses 1/2 of the amp circuitry, not unusual
- when I tried the SE output with the HD-800 it just didn't have the ooomph to drive 300ohm cans to their full potential, as others have noted in it's thread
- I recently received some custom balanced cables for both the 800 and 650, and the 650 was first up for a listening test, so here's the thoughts
- right away the soundstage opened up, very surprising since both IME and as read here the 650 is naturally on the intimate side of the soundstage spectrum
- the tonal signature of the 650 (mid-bass hump and slightly rolled-off highs) paired very well with the neutral-to-brighter BHA-1
- the resulting combo was a real pleasure. The stage was wider and less three-blobbish, the mid-bass bloom disappeared and the highs were more detailed and lively, leading to, I suspect, the increased perception of a wider stage and more air
- there is plenty of power on-tap in balanced mode to drive 300ohm cans to full potential
- detail was very good as expected with a SS amp, without being overly harsh or digital-sounding
- deeper bass was still missing as I expected as neither the 650 or the BHA-1 have much emphasis here
Overall it's a great pairing. I think it lacks a little of the musicality I get from my tube amps and is perhaps a bit more digital and grainy than the Crack or S.E.X. With the 650 it has a much more well-rounded or neutral sound than with the H-10, with less mid-bass but more FR balance and a wider field. I fear it may be a bit bright with the HD-800 which I'm only just warming to (pun intended) but I'll find out today.
I think I prefer the tube amps with the 650 over the BHA-1 for their musicality as they're more involving and a touch less analytical, but for those who prefer SS (20 year warranty!) or need a wider stage for classical or large-venue performances it's a very worthy amp. Factor in the cost of the balanced cables though or you will be disappointed.
In it's price-range it matches head-to-head with a Bottlehead Mainline which is supposed to be a very good tube amp and also capable of more than just high-impedance drive. I'm hoping to put that to the test sometime early in the new year.
Hope anyone considering this well-regarded and well-built amp finds the above useful, although it's just my opinion after perhaps 10hrs of listening time in balanced. Look forward to any thoughts from others who have tried the pairing!
An aside for this thread: so far the best pairing I've tried with the BHA-1 is with the LCD2.2c. The above is my thoughts with the HD-650. Next up: the HD-800.
