LOOOOOOOOOOOOOOOOOOOOOOL you guys are hilarious. Nah, payment received, can't back out now. But mucho thanks to DDDamian to giving me the time to A/B and now proceed to kick myself. jks.
In all seriousness though, spent a bit of time A/Bing different systems. I'm coming from an Emotiva DC-1 as dac for my BHA-1, to the Oppo HA-1. Here are my impressions:
JRiver -> Optical -> Emotiva DC-1 -> XLR -> Bryston BHA-1:
Well this setup I've been used to and what I will be using as reference. The DC-1 is a warmer DAC for sure, compared to my previous Schiit Uberfrost and my buddy's Mjolnir. Pair this with the flatline BHA-1 and HD800, I've got an incredible sound. I was pretty much ready to stick with this set for the long run..... until I got enticed by the feature set of the Oppo HA-1.
JRiver -> Optical -> Oppo HA-1 DAC/amp:
Without a doubt as Armaegis was saying, this combo is definitely 'brighter' or edgier than my previous combo. Would I call it flat? I'm not sure, I'm not a scope. But there definitely seems to be less of a low-mid range hump as I've had previously in the DC-1/BHA-1. I listened to it hours on end last night with no fatigue on my HD800. So maybe I'm just less sensitive to highs. But what WAS impressive was the soundstage, it is much wider than anything I've heard to this point. Orchaestral pieces, Lindsay Stirling's Moon Trance, anything with good dimension to it was well reproduced. I then proceeded to listen with the LCD-X, and confirmed there is a slight loss of mid-bass clarity and texture, but the rest is crystal clear.
I played with the other features a little too, the remote is slick, I can play/pause if I'm connected via USB DAC, or BT, but my favorite is the ability to mute preamp outs while leaving headphones on: I finally don't have to reach around my Adam F5s to turn it on/off. Mute! Only fault is the mute button is ONLY on the remote, and not on the unit itself. Guess I'll keep the remote handy.
Now that I've tried the combos, time to switch it up to determine the differences in DACs and amps
JRiver -> Optical -> Oppo HA-1 DAC -> XLR -> Bryston BHA-1:
So now using the HA-1 purely as a DAC, and the BHA-1 as the amp now, I felt only the slight loss in mid-bass texture, and a slightly less wide soundstage, but I'm nitpicking here and the overall sound is near identical. This was confirmed both on HD800 and LCD-X. hmm. maybe it's the DAC.
JRiver -> Optical -> Emotiva DC-1 -> XLR -> Oppo HA-1 amp:
Whoa yep. here we go, that's the biggest difference. The DAC. This sounds almost identical to my original setup. The warmth of the DAC is passed on through the amp, both amps running very transparent. Again the sound stage doesn't seem as wide on this setup for some reason, that I'm not sure why. But as for the mid-range bass drop in the pure HA-1 setup, the drop is nowhere to be found, if anything it feels a bit more accented here. Its nice on the HD800, breathes a little musicality into the heart of the analytical beast.
So.... I conclude for now: the BHA-1 and amp portion on the HA-1 is very very similar. The difference resides mostly in the DAC implementation of the DC-1 and HA-1 then. Slight loss in mid-bass range, but wider soundstage.
But dang yo. The HA-1 runs hot. like..... real hot. The build of the Bryston feels beefier and sturdier than the HA-1. Not to say the HA-1 isn't well built, its just how much of a tank the BHA-1 is.
DDDamian, guess your amp is safe, and I won't have to kick myself too too hard
![Wink :wink: :wink:](https://cdn.head-fi.org/e/people/wink.svg)
. It'll be on its way as we discussed and agreed. =)
Cheers all!
