Womaz
Thanks for the detailed reply, I will try and answer each point, if I dont answer a point it is because I either dont know or its not that important.Difficult question. Of course you can improve, but some questions first:
1. What sort of music are you listening to mostly?
2. What are your sound preferences?
3. What do you consider a significant improvement?
4. Which aspect of the sound do you want to improve? (Bass, trebe, mids, details, stage)
5. How much money are you ready to throw in?
6. The most significant change would be to take a new HP.
(I love the Meze Empyrean on the 3XP, but any recommendation shall be based on the answers to the above questions)
7. Add a tube amp, use the 3XR dac.
8. I would not think about additional dac alone, the xlr input on the 3XR can produce strange stuff.
9. Use the optical input (or perhaps the coax). I used to use my android phone into the usb input, but recently found that if I use the Cann Cube with optical out to the 3XR, the sound is smoother. I would not call the difference significant, but definitely there, and more pleasant to listen to.
10. I also have the new Burson power supply. The bass might be improved, but I need to make some additional A/B listening to be able to say if it not only imagined in.
1 Varies - i know this is vague but it is true. Last night for eg AJ Tracey, Kacey Musgraves, The Joy Formidable and Chvrches. Classical is the only music I never listen to
3 not sure I Just thought that a better HP would give me an improvement
4 again difficult , I love the bass on the HEK , but its missing on the HD800S. I love the treble on both HPs and the soundstage on the HD800S is excelellent IMO
5 5 TO 6K depending on trade ins for my two current headphones
10 Yes I have been looking into this option too
I think its between the Susvara , 1266TC and the Final Audio 8000D
