Tweakybiff
- Mar 26, 2017
So, I had one of the Conductor 3Xs, and there was hiss. I sent it back, and they sent me a new one that has no hiss, and sounds great! However, when it is in the "High" output position, it is really loud on my Audeze LCD-XCs, even on the "1" volume position. I have had an original Conductor, and the Conductor 2, and the volume starts off nice and low, and climbs as expected upon turning the volume knob. The Conductor 3X is silent at "0", but quite loud at "1". Also, as you turn to climb to 2,3, 4, etc., the difference between them is minimal, and the volume does not climb as expected, and seem soft. I have only used the Audeze with an XLR cable. I can use the "Low" position to address this, but the volume climb is still kinda soft, and I wonder if I am degrading the signal at all, or at least not optimizing it by having it set to "Low", not taking the advantage of the massive overhead the amplifier portion this box has. Does anyone have any experience with this?
As for the device, the 3X has super solid construction, is quite good looking, and the volume knob feels like something on a solid medical medical instrument. I have not played with the Sabre chip settings, but it sounds very detailed and smooth from my early listenings. Tons of power. DO NOT connect the XLR outputs to RCA adapters without using a Jensen ISO-MAX in between. The manual says it will blow the op-amps if you do. I like this box, but the volume issue is keeping me from loving it.
