epilogue
- Jul 29, 2015
Thanks piotr for the clarification! Now im starting to wonder if 8.2 was the right decision, but im sure it'll be an improvement over the H8P in any case
Well one thing I can tell you is that it's going to be some time before we have official replacement for 8.2 with FIBAE tech.Thanks piotr for the clarification! Now im starting to wonder if 8.2 was the right decision, but im sure it'll be an improvement over the H8P in any case
The amount of work required for adding another driver to the FIBAE system is basically exponential
They received one set of FIBAE 1 and 2 from us so far, so you could assume they have it in main shop, but it's possible they are touring it around other shops too.Hey piotr,
I'm heading back to e-earphone in akihabara tomorrow (it's 2am here, so really in like 10 hours). How confident are you that they have FIBAE line? I didn't see them in the store or on their website, but I'll ask around.
I also think I've decided to go with a dac/amp combo instead of a DAP. e-earphone has a used chord mojo that I'm going to try out ad pick up if I like it. Any yay or nay on that combo with either fibae2 or ei.3?
I would like to thank Piotr & Kamil for their patience and the amazing quality of their job.
I am absolutely thrilled, more than with my Ei.xx.
Ei3 vs Pro330v2 vs 8.2 - which one to get? This is coming from someone who exclusively uses Westone 3 reshells. Which one is the best bang for the buck?
Never heard Dragonfly Red I believe. For what it's worth I'm huge fan of Mojo, though. Note that with FIBAE2 you won't get huge sound difference between those two sources especially in regards to sound signature. Differences will be rather small.Hi Piotr, Wanted to ask - do you possibly have a comparison between Chord Mojo and Dragonfly Red? I have the latter and I'm curious if with your CIEMs (especially with FIBAE2) the sound difference between them is worth jumping from DFR to Mojo?
Coming from Westone 3 I would say Ei.3 or FIBAE2. 8.2 if you want TOTL performance. Cross out Pro330 unless you want to change your IEM sound signature 180degrees.Ei3 vs Pro330v2 vs 8.2 - which one to get? This is coming from someone who exclusively uses Westone 3 reshells. Which one is the best bang for the buck?
Thank you for your purchase!!!I would like to thank Piotr & Kamil for their patience and the amazing quality of their job.
AcrylicAre those silicone?
Can't wait to get my 8.2's finally. Shipping should be in about 1 week. Now I have to find the right pairing.
FiiO X5 III
Onkyo DP-X1A
Ibasso DX200
are my final candidates. What do you use your's with guys?
Cable will be from SilverFi (IEM X), a lovely Company with super good cables (for those who believe in aftermarket cables)
FiiO X5 IIIOnkyo DP-X1A
Ibasso DX200
