rotiprata
- Oct 23, 2014
how's the bass with the bigger drivers?
I dont think the new 1000Z will have a significant improvement over the 1000X. It would just a new can with different wood with improvement on the pads. I just ordered a pair of W3000ANV pads for my 1000X. I think it will do a similar job.
Ok, I had more of a listen and did some comparisons. These are brighter overall than my HD-800s. So we're talking more along the lines of the W3000ANVs in terms of sound.
I don't have any other woodies on hand. I had to bend the headband a bit to get something close to a proper seal. I could swear AT headbands are designed for people with watermelon-sized heads. I now have them sitting with fairly even pressure top and bottom, though the pressure is a touch too light for preference. I say this so that other people giving impressions can compare their seal, as a tighter seal will result in more bass and a lowered treble in my experience.
Anyhow, same as my feeling when I auditioned it in Tokyo, the W1000Zs are pretty good sonically for me. Out of the Hugo they are open and spacious sound, maybe with a bit of brightness/bite in the treble. Drums don't have as much impact as I'd ideally like, but there is a very good sense of instrument position, so that marks them as more "monitor" in presentation -- maybe more like a closed pair of AD2000Xs. Imagine a more forward-sounding pair of HD-800s in a sense. My impressions are from using them from the Hugo, but I've also plugged them into the Bakoon HP-01's current output as that tends to make some headphones sound a bit bassier, basically those with an increase in impedance in the bass region.
Unboxing:
i have this pair of cans in my sights as an upgrade from M50x, looking forward to your reviews!
In Asian fora it is stated that W1000Z is an improvement over W1000X and not a departure from W1000X sound signature.
+1
That's true!
Will post my review this weekend.
In Asian fora it is stated that W1000Z is an improvement over W1000X and not a departure from W1000X sound signature. It is also stated that W1000Z need to be paired with either tube / valve amplifier or at least with hybrid [ tube / valve + solid state ] amplifier. W1000Z has, reportedly, a full and energetic treble and a bit improved bass which is tighter. Tubes are needed to flesh out middle frequencies in relation to good bass and treble [ the tubes / valves give extra harmonic overtones]. When done so then W1000Z sound very good, balanced, engaging and with good dynamics.
These headphones are a good fit especially for the middle aged and older head-fi members. As men age they lose the ability to hear higher frequencies. Headphones that have full and extended treble help to make music sound right for them.
Looking forward to it!
Sent from my Nexus 6 using Tapatalk
Hmm I only have the ifi micro idsd right now as a DAC and amp though I hope to add on a tube amp or the ha2022 hybrid at some later stage.
Posted my review here:
http://www.head-fi.org/products/audio-technica-ath-w1000z/reviews/12506
ifi stacks:
[COLOR=383838]ifi micro iDSD >> ifi micro iTube >> ifi micro iCan >> Maestoso[/COLOR]
[COLOR=383838]Sound wonderful on Maestoso, highly recommended![/COLOR]
Thanks for your review! I like that you actually discuss amp pairings as well because that's pretty important given I only have the ifi micro idsd as an dac and amp currently. Would you think either the SHURE 1540 or SONY MDR Z7 would be better fit for my set up since those are warmer headphones compared to the w1000z? I'm also considering to bring the headphones around and I wouldn't think I would ever bring the w1000z out of my house. These considerations are for an upgrade to the m50x which I use at home and out about on trains/buses/walking outside
If you like the Audio Technica sound, try the EW9. Or the EW9LTD. I haven't heard the LTD yet, but the original EW9 is great. A really tubey sound. And you will look classy walking around with them.
