Hi all is the cup pads size bigger on the M50x then on M40x? Or is it the same.
Thanks!
M40x uses the same size pads as the M50x.
The pads discussed with respect to M50x all fit M40x, M30x, and M20x as well.
Thanks!
The increase in volume of air being moved between the drivers and your ears? Yes. The stock earpads' openings are too small.
Has anyone had problems with mismatched balanced between the drivers. I've recently had 2 sets of the ath m50x, one of the 2015 "DG" special editions (i much prefer the original design) and one pair of the original black m50x. Both seem to have this problem.
The DG's left driver was louder in general and had more bass than the right - I think these are actually faulty and have sent them back.
When testing the original black one using this http://www.audiocheck.net/soundtests_headphones.php the headphone matching test clearly pans right and then left in the higher frequencies. I've done the obvious switching the sides of the drivers and the panning changes sides. I'm going to take these back as well, but was wondering if I was just being too fussy. I'm fairly new to audiophile type stuff but have seen how well regarded Audio Technica are. Is a bit of mismatching normal or have i just been unlucky twice?
I just used my ears. The DG's were clearly biased, the black original just sounded odd, off and there was a kind of difference in pressure on the right side which is hard to describe but wasn't down to the fit of the pads. Thats when i tried the driver balance test and noticed the panning. I wasnt sure if this was a fault tho, but seeing that yours didn't do this I took them back., After some discussion they used the above site to check and they were found broken. Guess I was just unlucky twice.
I got a third set, small amount of panning around the middle when I've tried the audio check test, but they sound fine when music plays through them. I'm guessing that some inbalance is normal, at least at this price range. I did the test on a couple of other sets, grado sr80's and the over ear momentums, both pan a small bit but not as much as the M50x's. I tried a few different sources, nothing special, just through my mobile and couple of computers and they all did the same thing.
I just received mine like 2 weeks ago and I love them, I only wish they had an mic for gaming....but thats why mod mic exists...
