I agree there are so many variables., my system has a dizzing amount of components with a 7.1 surround setup and 2.1 channel dac/pre/amp combined. I run 3 separate 20a circuits with furutech outlets.
the 7.1 surround components are powered by a
APC H15 power conditioner on one circuit, subs on the second 20a circuit, and the 2 channel system has its own dedicated circuit.
All 2 channel system source devices are powered by a
Audio-GD HE-350 Regenerator or
Uptone LPS-1 Linear supplies (100% galvanic isolation)
So I have isolation there as much as possible on the 2 channel side.
There is only 2 ways that leakage currents/noise can get in the 2 channel system right now that I can think of
- over the network connection to the Streamer, so this new ether regen switch from uptone should stop that
- my speaker amp is plugged directly into the wall, so I am considering buying one of the filters mentioned on the precious pages by you for my speaker amp, not sure yet
Anyways, back to R2R-7, I listen to 99% PCM, but still listen to DSD sometimes, so its a bummer that the DSD with TDA firmware isnt supported for V1 boards.
However I wonder if it is worth it to sacrifice DSD to get better PCM sound via TDA firmware?
Maybe i interpreted it wrong but on I was reading on the Audio-gd site under R7 instructions and came across this line below that implies that the TDA mode can be turned on or off via the front panel (or in my case jumpers?).
I wonder if DSD works on V1 boards with it set to "R" mode?
Pll (Simulate SAA7220 +TDA1541A sound) :
t (TDA) : Active simulate SAA7220 +TDA1541A, digital attenuation low to -55DB, was -130DB. Bitwide low to 16bit , was 24 bit. While active this function, I are advice setting to OS2 or OS4 mode. But infact, this function can working with any setting mode.
r (R-2R) : Disable simulate SAA7220 +TDA1541A .
To answer your question, My R2R-7 has stock TCXO's and im kind of daunted by the idea of having to desolder them to replace them. my soldering experience consists of making DIY cables, never worked on any electronics yet and my R2R-7 is not exactly what I would consider simple to take apart and work on!
Will do, im pretty hopeful, as there is potential for a lot of noise to be on the Ethernet coming from other devices on my network.
