So it is correct that there is no hardware change or at least one does not need to change the front panel again to accommodate the Mck ? I am not thrilled about sacrificing the BNC though I only use that for my CD transport.Thanks for the link Fred. Everything you guys stated appears true about the R7-10M! And seems to me to retrofit the standard R7 to external 10Mhz capability is just reprogramming the three parts mentioned - Altera DSP, Xilinx I/O CPLD, and the front panel MCU (may be replace the PROM). Pictures inside the chassis indicate same wiring and did not notice any new parts added. No soldering involved hopefully.
Kingwa explains the new FPGA (parallel processing) very well in the translated website. These are W-I-D-E parallel data buses. DSD is 64-bits wide for each the left and right channels! I2S dual 32-bit, S/PDIF dual 24-bit.
"The parallel mode only needs one clock to process the 32-bit data of the left and right channels, which greatly improves the processing speed and is less susceptible to clock stability. The IIS input data is immediately reassembled into dual 32-bit parallel data. The SPDIF signal is demodulated and sent to the next set of processing through dual 24-bit data. DSD data is also reassembled into dual 64-bit parallel data processing."
Input #3 BNC is the 10Mhz clock input. No longer functions as S/PDIF. (Later: May have to replace a resistor on main board to change impedance from 75 to 50 ohm. So don't put away the soldering iron).
The front panel really changes up and is new in the sense the button functions/numerical display have changed from the current product. But to select int/ext clocking you just set it on the new front panel. To retrofit may require some relabeling of the front panel button positions. But think I will not mess with that to keep the panel looking pristine. The front panel MCU change makes that all work.
Yeah, big changes coming to the R7 near you!
And I presume I can possibly clock 3 of the Audio R2R DACs together using this external Mck programming ? This would be perfect for M-channel 5.1 playback!
