DACLadder
- Feb 16, 2013
@FredA. I’m confused as well and easy to do. R7-10M or new Di DDC?
Not sure what you mean, Scott.@FredA. I’m confused as well and easy to do. R7-10M or new Di DDC?
The 10M dac input is the icing on the cake cause with it, taking for granted the clock signal will stay relatively clean up to the altera, no reclocking will be done by the altera, just clocking, which means the lowest possible jitter.
So does it mean that ideally there will be an external master clock that clocks both the DDC and the DAC at the same time as the master clock correct ? This has been done by the Sony exoteric CD players of the past that used an external DAC and masterclock, I think,Not sure what you mean, Scott.
The whole point i think is to use the same external clock to drive both the r7 and the new DI.
This means the 10Mhz input has to be added the r7. This can be done by changing fw on the input selection cplds, on the altera flga and on the mcu which drives the user interface (to be able to select the external clock). Kingwa will make these new fws available to us at some point. In the mean time, it will still be possible to feed our dacs with the new DI, and even using an external clock with it as we do with the u16.
All clock signals coming from the same source. If not contamined, this means jitter as low as that of the clock.So does it mean that ideally there will be an external master clock that clocks both the DDC and the DAC at the same time as the master clock correct ? This has been done by the Sony exoteric CD players of the past that used an external DAC and masterclock, I think,
Yep. Not sure if i need any upgrade the way my setup as been perfoming lately, but WTH.You bring up good points. Get both DDC (other sources) and DAC on same clock domain should be make for a much cleaner path. No PLLs. No asynchronous data alignment. I like the possibilities a lot!
I’m having a strange sense of deja vu... like “here we go again”!!
Well i was actually echoing what Jan had posted. He seems to have talked to Kingwa. From what he wrote, there does not seem to have any hw change involved other than installing the proper input plug and and possible its corresponding cable. Unless Kingwa goes 75ohms, in whcih case there would be no hw change at all.@FredA. Thanks Fred! I was wrongly jumping ahead of developments and thinking you had info on how to modify the R7. Take a deep breath... exhale....
I just clicked. You mean all will be done through software, besides the fact that an spdif input has to be sacrificed to be used as a 50ohm clock input. Or 75 ohm. If so, i will likely get rid of the optical.
Or there are three other spdif inputs, so i suppose one of them could go. This is great news!
I have been taking my time to enjoy the R7HE - not leaving it to burn in unattended... it's been here for a week and I'm astounded how good the DAC is with staging, separation and tonality.
i encountered a DSD playback bug with the latest Asy3 firmware, this was verified by the official AGD distributor here in Msia with the shop's R7 as well - detailed feedback has been sent to Kingwa, so hopefully he figures it out soon enough. In any case, I listen to mostly FLAC and TIDAL, so to be safe I have just put DSD playback in Roon to "convert to PCM" for now.
tonight's hours are passing by enjoyably with my LCD-3F playing tunes from the Sansui AU-7700 and R7HE.
