Thanks all for your help.
Here's what I tested tonight.
All setting are tested in NOS1, NOS2, and NOS3. I did not test and OS setting.
I also reached out to Kingwa to get another copy of the R8 V3 firmwares. I was thinking that maybe the version I had was corrupt (His copy also produced the same results).
Note that USB is straight from computer motherboard to R8 Amanero card.
USB -> V3A firmware = all settings good
USB -> V3S firmware = all settings good
USB -> TDA-Syn firmware = All NOS setting bad with PLL off.
USB -> TDA-Asy firmware = all settings good
I2S -> V3A firmware = NOS1 and NOS3 still bad. NOS2 good.
I2S -> V3S firmware = all settings good
I2S -> TDA-Syn firmware = all settings good
I2S -> TDA-Asy firmware = all settings good
There seems to be a problem with the V3A firmware with the OCXOs installed. As @ItsAllInMyHead reported, stock clocks are good with V3A. Unfortunately, I never tried V3A before upgrading the clocks.
TDA-Asy still sounds great to me (better than the TCXOs and original R8 firmware) and that is what I am currently running now.
This was to test other firmwares to see what sounded best with the R8 OCXOs.
I am hoping the Kingwa continues to improve the TDAs firmware and releases a final update. It is my impression that the current TDA firmwares are still in the testing stages, but I could be wrong.
OK. Thank you
I will see how does it go with mine R8 on V3A.
I hope I wont have to change firmware.
