I got the idea of doing PCM on the fly to DSD from another fellow on Head-Fi but he is in a different thread. He actually abandons PCM altogether and only does DSD, He states he even can play CD and use HQplayer to convert on the fly to DSD. He only uses the DSD stage of the Holospring now and has sold his Pavane! So essentially even the holy grail of R2R NOS DAC may not be good enough ?! I am also wondering if DSD is more forgiving in that even inferior recording is not too bad. I tried a rather mediocre 24//96 file to play as DSD 128 but that sounded too sharp and artificial. However, when I used DSD 64, it sounded so much better, more air, better sound stage and much smoother and more transparent. I tried DXD (24/352) file (beethoven No. 5) and then compared to DSD128 of same track I bought from NativeDSD. They sound a bit different, DXD is more forward, maybe a bit more detailed but it feels like you are sitting 2 rows in front of the orchestra or you are at the recording microphone location itself. With DSD, the soundstage gets deeper, and more air/space between notes & instruments, more like sitting 10-15 roles back (I think that was a forward closed miked recording anyway). This is something others have observed from review I heard about DSD of this same recording. It is actually recorded in DXD and is available in DXD as well as DSD files/SACD. Reviewers love the DSD sound. Interestingly I then use the same DXD file and use audirvana to convert it to DSD128. I can hardly tell the difference between that and the DSD128 fie I bought from NativeDSD. So Audirvana may be that good! (or my DAC is not good enough to differentiate) . Also I am only using a Delta sign chip (ESS sabreDAC) so DSD may be better on such chip (per some expert) than PCM.
Now according to 6 moon, the PCM sounds as good as DSD or at least much closer to DSD.
It would be of interest to see how you guys feel about playing PCM vs DSD on R2R7 using the same file.
Note I feel (my theory anyway) that it would work better to try to convert to DSD that has similar resolution to that PCM file. If I remember correctly :
Resolution of DSD64 is about the same as PCM 24/96s, hence I feel for 24/96 one should be converted to DSD64 and not higher.
For 24/192, should try DSD128, but I have not tried that since I don't have such file yet.
For DXD perhaps DSD256 works best ?
But then it probably depends on both the OS/software and DAC being used.
You guys' input on the DSD sound of R2R7 would be of great help for me to decide if I should get it as I love DSD, ?!?! Hi Res PCM not that impressive but then using a R2R DAC may be quite different. I presume DXD would sound really awesome on R2R7. Anyone tried?
