There is a pretty big price jump from R7mk2 to R7HEmk2 compared to the R8(HE)mk2.Thanks OCC7N !
Since I already own a PS Audio power regenerator (their entry level P3) would the R7 MK2 + DI-20 work as well as their regenerated versions ?
I was planning to get the ACSS cable from Audio-GD as suggested by Kingwa. Would you recommend something else ?
My apologies if this is a dumb question, but when using an external clock, do you connect it to the DI-20 and/or the R7 ?
You power conditioner(P3) looks great, I think though even further improvement will benefit you, and if you can do that on a dac, I would. I have also read people even upgrade/attach the power cable(on P3) with Furutech Flux-50 NCF, so even the conditioner, gets improved. It sure helped my iFi powerstation also
What Im trying to tell you is if you are really critical, and can hear the differences in most scenarios, the last percentages of an REG PSU will be noticeable. But if you just the casual listener, like I am 80% of the time, then you are still more than fine with those models imo.
Atleast go all in on the DI20 and get the HE. This thing has its secrets! Its music, engaging. It does something with the timing, I can not explain. This thing should get an award, and Im not joking. The R8 sounds great without, but DI20HE sets everything in its place, its like the engagement of the music/elements catches my senses off guard, this is without master clock.
Note this when you get the master clock: Master clock only has 10Mhz outputs either with 50Ohm or 75Ohm connection(buy BNC cables accordingly), this did confuse me in the start. DI20/HE has 2 port, one says EXT CLOCK. This port is not being used, leave it open. Only ports that you should use is the 10Mhz inputs on you audio devices. DDC, DAC.
