New Audio-gd R-7, R-7HE R-8, R-27, R-27HE, R-28 Flagship Resistor Ladder DACs and DAC/amps
Aug 10, 2022 at 8:54 AM Post #8,881 of 12,025
Thanks. I'm still a little confused about when the DI-20 clocks are/are not used. I was under the impression that the Di-20 clocks are used when going out over I2S. It seems this is not the case. So just for my knowledge, when in fact would the DI-20 clocks come into play?
Part 2. The question is what is DI20 clocking and if the DI20 really is operating in Asynchronous?
DI20 clocks the incoming USB signal and converts the USB signal to one of the following: SPDIF or I2S. In order to convert the signal, it needs to be clocked, i.e. re-clocked. Yes, it must be re-clocked because USB, I2S and SPDIF are completely different types of digital interfaces that do not speak the same "language".
Because DI20 only has USB on the input and no USB output means that DI20 cannot be controlled by Asynchronous USB from the DAC. No USB cable between DAC and DI20.
That means that when you use SPDIF out to your DAC, it is DI20 that dictates the timing for the packets to be sent to the DAC. With I2S, it depends on the DDC because the I2S interface/protocol can be made to operate both as asynchronous and synchronous.
Aug 10, 2022 at 9:06 AM Post #8,882 of 12,025
Thanks for this clear explanation. Does the DI-20 have a setting for I2S async or sync? Or is it async by default? If it has a setting, I can't seem to find it.
Aug 10, 2022 at 9:11 AM Post #8,883 of 12,025
Async is the method of by which usb operates, its not a setting. It just means that its not linear, it sends data in chunks.
Aug 10, 2022 at 9:13 AM Post #8,884 of 12,025
Well. I use I2S between my DI-20 and HE-7 and recently I changed the clock cable feeding my HE-7 and it made a significant improvement. So, I2S is not dictating the clock over my HE-7.
I ordered the same clock cable for my DI-20 to see if improves things.
Aug 10, 2022 at 9:46 AM Post #8,885 of 12,025
Yes I believe Audio GD, PS Audio and many more companies makes DACs which operate in asynchronous I2S. The clock cable is super important. Both quality and short length.
Aug 10, 2022 at 9:53 AM Post #8,886 of 12,025
DI20 haven no switch for that. If IIRC it has to do with which i2s lvds pins that are used if it will operate in asynchronous or not. Scott probably know more about this, I think.
Aug 10, 2022 at 5:47 PM Post #8,888 of 12,025
We haven't seen any reviews since it's very new. But, based on past devices if the R-27HE has the feature set you want you should buy it with confidence.
Aug 15, 2022 at 11:27 PM Post #8,890 of 12,025
Hi all, can someone refer me to a review of R-27HE please.
I've written a review, but due to a bunch of things that came up, such as my air conditioner failing and having a bunch of students wanting to take the standardised English tests not long before the date, I've been delayed finishing it.
In short though: It's not quite a HE9 + R8, sounding only (in comparison) a bit less resolving than a TT2 as a DAC, and not quite the Studio Six as an amp (unless driving LCD-Rs or Susvaras). Headphone drive is outstanding. It sounds the same plugged into the wall or a power conditioner. It's weakest point is that it's best with a good I2S transport + HQPlayer, but with those things I would be happy with it as my only DAC/amp and not miss tubes, though it doesn't sound warm at all, unless you compare, where it's only very slight. It also, as usual, needs some hours switched on to sound its best.
Aug 16, 2022 at 3:38 AM Post #8,891 of 12,025
I remember air conditioning :(
Aug 20, 2022 at 12:16 PM Post #8,892 of 12,025
The usb receiver regulates the data flow. The usb receiver works in synch with the fpga, using the same clock. So the jitter level out is that of the clock signal derived from the Accusilicon XOs, so ultra low.
Aug 24, 2022 at 9:25 PM Post #8,893 of 12,025
Can anyone check the distance between the feet to the left or right edge of the R8 mk2?
Considering this dac but I want to make sure it will fit on my desk.
Aug 25, 2022 at 3:49 AM Post #8,894 of 12,025
I can't get mine out of its position in my rack :(
Aug 25, 2022 at 10:04 AM Post #8,895 of 12,025
I can't get mine out of its position in my rack :frowning2:
You want to know the actual footprint on the ground, correct?
Is an eyeball with a tape measure close enough, or are you cutting it that close?
