@Chopin75 I listened to single ended outputs for years with the M7 and S7. Sound quality was excellent. Yes twice the signal (voltage level) on balanced outputs. But your ear works logarithmically so it may take more signal to seem twice as loud.
And that silver cable may take a while to run in a bit. My silver Litz cable took about 3 months but is excellent for detail.
As a side note.... Years ago I looked in the back of my DACs and noticed the signal ended outputs were just the (+) signal from the balanced output. ?? Scratching my head I thought in using single ended I was only utilizing one side of my balanced DAC. As Kingwa explained to me on the M7 the single ended, balanced, and ACSS outputs use the combined positive and negative balanced DAC signals to form signals to drive the cables connected to the DAC outputs. So Kingwa decided to use the full balanced DAC signals (with all the benefits) to create the signals for all outputs.
After using a "true balanced" amps where the two balanced input signals are kept separate until the speaker terminals I like the way Kingwa generates the output signals. Much less complicated and less parts plus has a lot of benefits for simply moving a signal waveform from one unit to another over a cable.
