Up on the cloud drive is new hybrid Smooth/Accurate firmware compatible with IN4 optical (R7V2SA-T.jic)
Kingwa called the new file R7V2SA-T. To be consistent the IN4 I2S version R7V2AS changes name to R7V2SA. Same file (R7_V2A.jic) but different name. AS or SA you get the picture.
I also renamed the following IN4 I2S files to be consistent with the new naming scheme. Nothing has changed with the files - just consistent naming. Older named files removed.
Note.txt files added to the cloud directories to explain files and jumpers.
https://onedrive.live.com/?id=636DC4E8060D66A1!172&cid=636DC4E8060D66A1
IN4 I2S
R7V2S.jic = R7_V2.jic (V2 Smooth release. Checksum 0290DCAD)
R7V2A.jic = R7_V2A1.jic (V2 Accurate release. Checksum 02868CEA)
R7V2SA.jic = R2_V2A.jic (Originally referred to R7V2AS. V2 hybrid Smooth/ Accurate release. Checksum 02989AA9)
IN4 Optical
R7V2S-T.jic is improved based on original smooth version. (Checksum 028E594E)
R7V2A-T.jic is improved based on the original accurate version . (Checksum 028B0279)
R7V2SA-T.jic is between on R7V2S-T and R7V2A-T configure. (Checksum 028FF4CD)
I did verify the checksum of the renamed IN4 I2S files and matched up to the older versions. Please correct me if anything is wrong.
