FredA
- Dec 15, 2013
His own r2r 7.Just confused about whether it was his problem or his friends, but I will try out different connections tomorrow and see
Problem is with my R2R7. My friend did not install the new firmware in his R2R 1.Just confused about whether it was his problem or his friends, but I will try out different connections tomorrow and see
I guess you should report this to Kingwa. This could be a bug. Possibly an uninitialized variable, assuming it is possible with the language he uses.Ok, I flashed back Accurate firmware and everything works perfectly: optical OK, BNC with no noise. I then installed the new firmware again and voilá: optical not working anymore, but BNC doesn't seem to be making any noise anymore.
Already doneI guess you should report this to Kingwa. This could be a bug. Possibly an uninitialized variable, assuming it is possible with the language he uses.
Try getting the file again, it may be corrupted. Or I can send you the one i use by email.Well...BNC is doing that weird noise again. It's like listening to an old dirty vinyl. Unfortunately, this new firmware is a no-go for me, too many troubles. I'll be forced to go back again to Accurate.
I will try to invert polarity, i am curious. This is a simple fix for Kingwa if effectively the case.Fred summed it up just about right. It's the most analog sound I've ever heard on these 105dB speakers. Love Music Nuda but there are so many high pitched passages that I simply have to turn the volume down for -- that was not the case with this firmware. This is the most listenable my system has ever been. The stage stepped back a bit, creating a more respectable distance between speaker and listener. Fred said it would be a good match for a system dialed for high transparency. He's right -- I'm listening to an Ultraverve 3 6sn7 preamp right now, and I'm eager to try my T+A solid state preamp again.
I've had this DAC for almost a whole year and this is a very welcome change. Unfortunately I think the phase is flipped. It sounded like the leading edge was subdued, and then I heard an audience clapping and that was a dead give away. In JRiver24 this sounded much better...
