kenman345
- Nov 22, 2011
Anyone using the DAC-19 in NOS mode? What isthe perceivable difference you have found?
Hi.. Jus to share the best settings I found is leave it at default but turn of PLL .. It improves a lot on bass details n clarify n reduces the bloated loose bass
Thanks
Has anyone else turned off PLL on their DAC-19? impressions please?
The default settings were significantly better .
I tried all other settings with my master11 and they all sound like something is missing or thin in some way. Pll off doesn't make a difference with my setup as its so low of jitter but likely would cause some issues with some systems. I didn't notice an audible improvement with it off. But will try again as I now upgraded my USB source to a Paul pang v3 OCXO. No idea if this will matter but worth trying out to see.
Otherwise, Kingwa sets it up they way he does for a reason. Sounds sublime![]()
How often do you turn off your M11? It draws full power whilst its on right? That's one of my major concerns, I do want to keep the DAC on, but not keep the amp on along with it drawing so much power and heating up. Seems like it would have been a good upgrade from the DAC-19.
Has anyone compared these three DACs.
1. Audio-GD 19 ($650)
2. Schitt GMB ($1250)
3a. Chord 2Qute ($1800)
3b. Chord Hugo ($2500)
All are in the running. Coming from a Meridian Director.
Input will be USB / HTPC.
Output will be RCA.
DSD/DXD not a concern.
Portability not needed (just an added fun factor of the Hugo)
Stillhart has tried both DAC 19 and GMB
Output will be RCA.
Could someone please explain the options to me?
http://www.audio-gd.com/Pro/dac/DAC1911/DAC19EN_Custom.htm
1. Does it come standard with RCA outputs or do they need to be added? Never heard of ACSS.
2. Not needed. I need USB.
3. What is that?
4. What is that?
