originalsnuffy
Is there any general consensus on what the better replacements for this unit might be. Does not have to be this brand
you could have driver flex on both sides, try blowing air into the nozzle with your mouth (a short burst) and it might fix it. Seriously it has worked for me with my pair. If it does work u probably should use tips that don't seal as savagely.Any info on warranty of the A2?
My LZ A2 seem to have died on the bass side on both sides.
Got them last november 2015 at http://faith-audio.mybigcommerce.com/ but website is down...
To expensive to just throw them into the bin after one year.
Will give that a try.
But if that doesn't solve the problem? They are only one year old.
Any warranty procedure with LZ?
How to contact them?
Just to inform that i just received an offer for Head-Fier for the pre-order of the new earbuds **** PT15!
Pre-order price as following:
Code:Without cable:$8 With black、blue、green cable:$14 With silver cable:$19.9
You can check this model at this AliExpress page:
Code:https://www.aliexpress.com/item/New-****-PT15-In-Ear-Earphone-Earburd-Graphene-Dynamic-Driver-Unit-HIFI-Earplhone-Earplug-With-MMCX/32752982333.html
P.S.: i don't know if is legit to post this link! Please tell me if i need to remove it! Thanks!
