I found a good low cost amp option for NDH30. I have an old AMB M3 (details here:
https://www.stereophile.com/content/katz’s-corner-episode-7-mosfet-magic) that has been gather dust for the past few years. On a whim I bought a pair of Staccato Audio discrete hybrid opamps (details here:
https://www.dagogo.com/staccato-audio-discrete-hybrid-opamps-review/) just to play around with them. After some fiddling and adjustments, I can safely say that the AMB M3 with Staccato Audio discrete opamps perform very very close to my GSX amp with NDH30, with M3 being slightly warmer than GSX but GSX goes a smidge deeper in the bass.
The long and short of it is both amps perform very close with each other when driving NDH30.
Interesting upgrade! A couple of months ago
I used two pairs of Staccatto Audio discrete opamps (2 dual + 2single) to upgrade my Rotel RCD-991 CD player (about € 800 when new) . It is old (20 years) but I like it very much as a device so I thought I could give it a new life. The improvement was immediately audible but not as significant as I'd wish, maybe because the original Burr-Brown and Philips integrated opams were already very good. However, more detail, harmonic tones and ambience was added to its sound, making it more "open" and bringing it very close to my best sounding CD player, which is not my most expensive: a recent Denon DCD 100 compact or 2/3 size player (€ 600). This one I use as a CD transport for my headphone system because it is small, silent and of very high quality.
Continuing about my
dac comparisons that I mentioned earlier:
The last two nights I had a very hard time trying to tell which combination sounds best:
- the above Denon as a CD player or,
- the Denon as a transport feeding the
Cambridge Audio azur DacMagic.
They are VERY close to each other but finally there were some times that I juuust heard the Denon as a player taking the edge over the Denon+Dacmagic. The opposite happened less times.
It is now the turn of the
Musical Fidelity V90 DAC + V-PSUii power supply to be compared with the (stand alone) Denon. My brief initial impression is that the MF V90 surpasses the internal dac of the Denon. If this is further and clearly verified (blind listenings), the V90 will be compared with my references: The Chord Qutest and the internal dac of the Lehmann Linear D II. (Everything is listened to through the Lehmann + NDH 30).
These two personal references very easily glow above anything else I have, but it took me very long and tiring listenings to just tell that the Qutest has a little (very little) more natural mids than the internal dac of the Lehmann. They are both TOTL dacs, tremendously detailed and natural, with the "blackest blacks" at the silent passages. Their little difference, which is at the limits of audibility, was finally revealed when I got the NDH 30 but was totally inaudible with the HD-650.
