Rob80b
Strictly as an amateur though....could never finish practising my scales as I'd always get distracted and start improvising for an hour or two.Oh Yes, I remember now!![]()
![Musical notes :notes: 🎶](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f3b6.png)
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
As an amateur recorder player, soprano to bass, I can empathise with that. Bach wrote some wonderful flute work, and recorder work too. Did you ever take a look at Telemann? His Fantasias for solo flute are incredibly fun to play.Strictly as an amateur though....could never finish practising my scales as I'd always get distracted and start improvising for an hour or two.![]()
I must have over the years….but just to be sure…..………….. Did you ever take a look at Telemann? His Fantasias for solo flute are incredibly fun to play.
I did suspect that was the main reason....USB is one of the worst ways to connect a source to DAC. Best to worst: proprietary fiber optic > ethernet network > I2S > AES > toslink/spdif > USB > Airplay > Bluetooth
My iMac doesn't have an optical out AFAIK, unless it's disguised in some way? Where would you plug in the adapter? Is there an optical out hidden in the 3.5 headphone jack??Too many variables for me to give a definitive answer….many say usb is the last route but most iMacs have an optical out to double check… though you’ll need an adapter for the audio port.
Was thinking optical and toslink should be rather close, probably depends on the implementation, some mention preferring it over optical...I could never tell but haven't had enough experience with multiple DACs.USB is one of the worst ways to connect a source to DAC. Best to worst: proprietary fiber optic > ethernet network (fiber SFP) > ethernet network (RJ45) > I2S > AES > toslink/spdif > USB > Airplay > Bluetooth
Yes..it's integrated with the 3.5 headphone jack....been for years but many do not know this so you are not alone.My iMac doesn't have an optical out AFAIK, unless it's disguised in some way? Where would you plug in the adapter? Is there an optical out hidden in the 3.5 headphone jack??
It’s late 2014. I can’t afford new computers you know – buying too many headphones instead…..Was just checking..it may have been eliminated after 2017 so depends on the age of your iMac.
Fiber and toslink are two completely different animals. Toslink is based on SPDIF protocol and will have clock muxed with the signal, which the DAC would need to de-mux and recover. Proprietary fiber means a completely different codec for the audio signal that is specific to a brand (Emm Labs, Playback Designs for example) and the digital signal and clock can be sent separately or not at all if there is a separate data cable connecting the dac with the source. Network fiber (SPF) is just your everyday ethernet but using fiber to eliminate any noise. I have seen folks doing the RJ45 to fiber to RJ45 which I think is half-assed way, because you are reintroducing potential ground noise into the system via the RJ45 connector (yes even though the RJ45 is transformer coupled, that doesn't eliminate all noise).Yes..it's integrated with the 3.5 headphone jack....been for years but many do not know this so you are not alone.
Ok thanks....Haven't lost much sleep over it, only connection I have going on is an optical cable from my OLED TV to one of my Cambridge CXN although I have a coax and or optical running from my CXC CD transport to the other CXN in the living room.Fiber and toslink are two completely different animals........
Why do you specify that order of quality?USB is one of the worst ways to connect a source to DAC. Best to worst: proprietary fiber optic > ethernet network (fiber SFP) > ethernet network (RJ45) > I2S > AES > toslink/spdif > USB > Airplay > Bluetooth
