Mike F
- Dec 11, 2009
Recent review with some measurements:-
That's why I despise most youtube reviewers. They're just churning out empty "reviews" so they get more gear.Did the reviewer just read the ad Neumann handed him, ran some b-rolls and explained some graphs other folks generated? What am I seeing there? At least he was honest about getting a free pair of cans.
I think it is possible. I only did it with a stock cable of the HD-560S as a cheap solution for the NDH-30 (described some posts earlier). The most "difficult" part is to prepare the individually insulated strands (litz type?) for soldering because as they are they don't accept soldering. The insulating enamel has to be burned for half a second first with a very small flame (small lighter) and then scrape/clean it to leave only pure copper. It can be frustrating but it works. I think the enamel can be removed chemically too, so maybe someone can propose a proper way. The NDH 30 stock cable is internally symmetrical so theoretically it can be well modified with a new plug at the amp end. Possibly it is of individual strand insulation type, too. For 4.4mm "pentaconn" type plug choose one with enough room for soldering and cable attachment. I worked with smaller ones and it was challenging/time consuming. XLR types have no problem with room and soldering. Bigger "pentaconn" plugs can be found at around € 30 or more. I would absolutely prefer to modify the very high quality stock cable (€ 80 as a replacement) leaving its proprietary 2.5mm plug at the headphone end, than ordering a custom cable.Has anyone tried re-terminating the stock cable with a balanced connector? I don't see why it wouldn't be possible, but it would be nice to have confirmation.
Great that you enjoy such a wide variety of music! I can only say that although taste in headphones is always very personal I'm sure the NDH 30 will satisfy your needs and requirements. They're certainly well built and the original box is very usable as a storage case if you so wish. It's very accurate and neutral and yet engaging at the same time. A studio monitor intended as a professional tool which is also enjoyable to listen to music of any genre on - a rare feat! That's my opinion(!), but let us know how you get on with them. I'm sure you won't be disappointed, but your honest feed-back can be helpful to others.I have a few questions, if anyone would be so kind as to answer them. I've been using a pair of Fidelio X2s and some Fiio FH5 iems for a number of years now with pleasure, and I have been saving money with a view to buying a high quality set of open backs that will last for the foreseeable future. I want to buy once, with no view to further upgrades, and I want them to be sturdy. These headphones have caught my eye, and I am hoping to pick up a pair next month.
I listen to a very wide range of different types of music, and want to make sure I'm not making a faux pas by buying something expensive that will not be suitable. Unfortunately, I am disabled with quite restricted mobility, so I am not able to sample headphones in a store.
I listen to a lot of 'classical music', particularly baroque era, and from the late romantic era through to modern music, running from Mahler and Bruckner through Schoenberg to Ligeti and Shostakovich. I strongly value natural timbres, capturing the natural characteristics of harpsichords, oboes, recorders, etc, as well as decent imaging required for large scale orchestral works and dense chamber ensembles.
Similarly I listen to a lot of jazz, from early and scrappily recorded dates all the way up to very dense large scale collective improvisations. Same goes for electronic music, where I listen with as much pleasure to home made lo-fi jams, all the way to the super precise pointilism of Autechre. I enjoy a similar range in pop and rock forms, but veer more towards the experimental side of things than the traditional, precisely mixed audiophile fare.
For me, I have no issue hearing the roughness in a recording when there is roughness present. I'm as happy listening through some grot on an old Melodya recording as I am on a lovely ECM disc. I am hoping for a pair of headphones that are entirely honest, and will accurately reproduce whatever I put through them. I understand that this is one of the main points of praise with these headphones, but would value input from any fellow crate diggers that like music off the beaten path.
With this in mind, do you think the Neumann NDH 30 will serve me well? Any comments would be greatly appreciated.
While I haven't heard the X2, I think the Fidelio X3 is very good and understand it's quite similar. I think it images very nicely, perhaps at the expense of some detail. I must say I think the X3 is very engaging. But I think you might well find the NDH30 better overall: more linear, with greater extension, less coloured. You might, however, find the imaging less convincing. These are very subjective impressions of course - very hard to predict how others will react to these nuances. If you're interested in other options, I find the Sennheiser HD800S better than the Neumann in all respects just mentioned - particularly imaging - but about twice the new price. It can be found used for about the same price as the Neumann new. The Beyerdynamic T1 (G1) is not current but can be found used for about the half the price - and I think it's also better in all relevant respects - I find it more accurate in terms of timbre than the HD800S, but not quite so 'grand' in its presentation. I think you would need pay a lot more to do better. I should add that I listen to a wide range of classical music - I particularly like chamber music.I have a few questions, if anyone would be so kind as to answer them. I've been using a pair of Fidelio X2s and some Fiio FH5 iems for a number of years now with pleasure, and I have been saving money with a view to buying a high quality set of open backs that will last for the foreseeable future. I want to buy once, with no view to further upgrades, and I want them to be sturdy. These headphones have caught my eye, and I am hoping to pick up a pair next month.
Is there something that you don't like on the X2 and want to improve? Do you like its balance? Do you need full bass extension? Maybe describing your experience with that could help us propose something more successfully.I have a few questions, if anyone would be so kind as to answer them. I've been using a pair of Fidelio X2s and some Fiio FH5 iems for a number of years now with pleasure, and I have been saving money with a view to buying a high quality set of open backs that will last for the foreseeable future. I want to buy once, with no view to further upgrades, and I want them to be sturdy. These headphones have caught my eye, and I am hoping to pick up a pair next month.
Well let me start with I'm more of a metal/rock guy so I don't know your preferred genres well, though I love to dabble and experiment. Probably the closest I come to your listening is Jazz, it's become my new addiction. I had the X2 briefly but returned it. I didn't think it was a bad sounding headphone, but the treble on it was a bit too much for my tastes. At my desired volume it was just too shrill at times, making me either turn down the volume and enjoyment, or get headaches.I have a few questions, if anyone would be so kind as to answer them. I've been using a pair of Fidelio X2s and some Fiio FH5 iems for a number of years now with pleasure, and I have been saving money with a view to buying a high quality set of open backs that will last for the foreseeable future. I want to buy once, with no view to further upgrades, and I want them to be sturdy. These headphones have caught my eye, and I am hoping to pick up a pair next month.
Then get the NDH 30. Let us know what you think!The reason I landed on the NDH 30s as an option is because of the flat frequency, the bass extension, their reportedly natural presentation, and the fact that they seem to sit at at a good price to performance point. I certainly do not want to pay more than their price tag, this is my upper limit for the moment.
Does that help?
