jon parker
Just to re-iterate (I am also a full Sound Engineer
This headphone has the good quality of revealing what is in the mix
It is not completely neutral as the low end is often noticeably noticeable in the mix HOWEVER it CAN give an exceptional & accurate representation of the percussion... >>Sometimes<< - depending on the track. Sometimes though I do find there is a little bit too much emphasis on the lows - Not enough to spoil it for me...but irronically, enough to make realise that its not far from perfect in some regards
In general Im finding that the NDH 20 does not have a lot of respect for less than optimally mastered audio!
> In case we forget - This is a closed back headphone !!
In the sense that the NDH20's are quite revealing this means that sometimes the mids may well SOUND like they are scooped out and and other times they may well SOUND perfect - Assuming of course you are all listening to a qualified well recorded mixed & mastered source ?
How this is perceived will also depend on what your other reference points may be
There has been a recent upsurge in people taking as gospel a graph that 'someone' has posted online - This really needs to taken with as much reliance as you would receive from seeing a patch of green area with the appropriately symbolised types of trees on a map - You can glean that there is a wood or forest there and can get a rough idea of the type of forest BUT this is nothing like the experience of actually standing in the middle of and experiencing the forest in person !!
Its a very 1 dimensional tool to give a very rough idea of what a headphone might sound like - But with IEMS for example - all you need to do is change the seal or tips and that graph is then, often completely different
End of the day - I have had some amazing sessions with them and have been almost completely happy with the sound
Also today i did some editing with them and found the tonality of the female vocals and the resolution of the audio as a whole to be surprisingly good...in fact pretty much spot on - perfectly revealing the sound of the female vocals and the characteristics of the particular mic used
