12345142
- Nov 14, 2009
The Phiaton's are pretty appealing. so i went to my local futureshop today and checked out some headphones. I ran into the bose qc2 (i think). They had pretty awesome noise reduction and sharp audio and i loved the soft cups and how it perfectly enclosed my ear. How does this compare to the Beats and Phiatons in the aspects i mentioned? (from best to worst)
Thanks
You probably ran into the QC15s. They're something like $500. Have you read Stereophile mag and '|joker|'s' reviews on the Phiatons? The MS400s have some of the softest earpads around, they fold flat and collapse into a ball, also come with a case, and aren't totally dependent on batteries. You'll likely get at least the same degree of sonic performance as Bose, if not better. Active noise cancellation is generally frowned upon at Head-Fi, as the circuitry and signal processing tends to create artifacts in the music.
By the way, 'perfectly enclose the ear' is a base standard for these headphones anyways. That's exactly what 'circumaural' means. Look, if you just want to get Bose, though, by all means go ahead.
