captian73
- Jun 30, 2006
get the Senn HD25-1's. They do noise cancelling better than all the usual noise cancelling headphones!
The Phiaton's are pretty appealing. so i went to my local futureshop today and checked out some headphones. I ran into the bose qc2 (i think). They had pretty awesome noise reduction and sharp audio and i loved the soft cups and how it perfectly enclosed my ear. How does this compare to the Beats and Phiatons in the aspects i mentioned? (from best to worst)
Thanks
I think i'm gonna go with the Denon d1001's. Anyone object? or wanna add any comments to make me feel more confident in buying these? i mite get an amp later wen i get more $$$ but as of now i dont really need one cus i really just need em for portable use like on the bus or just walking. Thanks for everyone's contribution to my decision! I will tell you guys my initial reaction and experience with these. i'm so exicted.
Most of the cans I'm seeing are rather below par in terms of standard sound quality. QC2? Unless you fly in a plane 24/7 I don't see why anyone would pay that much for Bose's sub par sound quality...Look at the Pro 750 or Hfi780. Here's the thing, for your price range you will want to add an Amp or DAC to drive those cans properly.The average quality headphone for $200+ will require power. If you use your iPod alot, try out the Fiio E5, I hear good things about it.
If it is the same bose that I've auditioned at futureshop, I find SQ terrible. It's bordering on shrillness.
Uh, did you only read the first page of the thread? I said a mouthful about Bose myself. The OP does not like IEMs, is looking for good isolation, and hopefully a folding design, although feel free to correct me. Seems like the choices now are the aforementioned Ultrasones, HD25-1 IIs, or to just swallow one's pride and get the MS400s at a less discounted price.
About the Fiio E5 (haha you've got me interested now). How much difference will you hear with the Denon D1001's? cus i've heard from other reviews that it doesnt do much. I'm interested in the E5 cus firstly its so damm cheap and secondly its so small -- perfect for portability. Any thoughts?
D1001 wouldn't be a bad choice, however I tend to steer clear of Denon. I personally believe they are revered not because of the way they sound but because of the way they look and their relative comfy-ness. I think for the same price range there are many other pairs of headphones that would do just as good a job delivering quality reproduction of your specific music tastes. Heck, you can probably find some cans that would suit you for less than the D1001s, and they wouldn't contain a muddy mid range and loose bass. Check our the Turbines, they are the only product by Monster that Head-Fi loves. Also, UE makes nice IEMs, i just hear some of the models can be uncomfortable.
