The biggest problems I had with the IE8 was the bass emphasis that required EQing to fix (bass knob only adjust the bottom half of the bump, i.e. not useful enough), that the driver is slightly sluggish on the top end which smooths off the details some (sensitivity is there but not the fidelity), dynamic emphasis is slightly tamed, and that the sound stage was always distant even for things that sound be close meaning layering and separation suffers.
The biggest problems I had with the MTPG was that the driver is rather smooth and bordline muddy and does not handle complex passages well without moderate blurring of information, and the treble is rather smoothed over which may or may not matter depending on preference.
The biggest problems I had with the C751 was that the bass is poorly controlled at higher volumes (amping helps partially), it has zero and I do mean zero isolation for an IEM format, the quality of sound is clean but a little grainy in nature, and the frequency response is quite sensitive to tip choice (stock, small, single flange tip not the best choice).
The biggest benefits of the IE8 are that the quality of sound, short the top end, is very good (clean, well defined, natural), the driver is a monster with very high throw and remains remarkably clean to painfully high volumes, bass is among the best (athough I still prefer the UM3X bass), and the sound stage is massive relative to most other products out there which is fun to listen to.
The biggest benefits of the MTPG is its very good frequency response balance and extension, hearty and well textured note, surprisingly open and almost airy sound (especially for a thick note), and mild top end (if you like that).
The biggest benefits of the C751 is that the driver is effortlessly articulate and dynamic with well defined texturing and details, has a very realistic sound, and the sound stage is pinpoint and well defined.
The IE8 does sound quality better than the other two. The actual presentation of the note is cleaner.
The MTPG does balance better than the other two. The frequency response is quite flat and extended. Bass is deep yet very well controlled, almost tight. Mids are even with the rest (almost forward if you're not used to something that doesn't have a V shaped response). Treble is actually extended, but smooth in nature but remains well balanced with the rest.
The Denon does note development and sound stage better than the other two. Dynamic range is effortless and large. Notes are more chiseled and clear cut than the other two (articulated). Realism of sound is better than the other two. The sound stage is better with location, distance, and layering versus the other two.
What makes which one the best is up to what you deem important. All I can really say is the IE8 is a neat earphone. It's quite good really and is definitely a top tier product. I personally can't live with one without EQing. It also needs a powerful amp to really push. I almost top out my Meier 2Move before it even reaches its mechanical limits, It is a beast of a driver. The funny thing is it's also quite happy off squat for power too and doesn't noticeably sound bad doing it, but the driver is power hungry if you have the wattage for it. The MTPG was a pleasant surprise when I borrowed a pair for a while. I was actually expecting worse. It's a good product but with key shortcomings. For a high end product, I really can't forgive a muddy presentation. It's not a wattage issue, so the driver is simply built wrong, and that's just dumb. There are better ways to get the sound signature without creating a muddy earphone. The Denon C751 impresses me every time I use it. The sound quality isn't top notch, but it does everything else amazingly well. Very few earphones out there can match the effortless dynamics, articulation of note, nor realism of sound. Despite all the high end earphones I've used, I still really like the C751. It is very easy to drive, but I find amping helps control the bass. It's still an earphone I could be happy with on a daily basis, more than the other two, but some of that is personal preference and what I personally want an earphone to do.
