Feb 28, 2011 at 9:19 AM Thread Starter Post #1 of 1
AlmaataKZ
Hello, Head-fi-ers!
I have been reading this site for several months (thank you!) and finally decided to register. I see there is a lot of experienced people here and I hope I can get some help.
I have gone through a major upgrade of my hifi kit in the last year (check this if interested http://community.whathifi.com/forums/t/392544.aspx) and I am now in the final stage - upgrading the ear phones.
I am after a pair of high-quality in-ear monitors for long-term use. I will be using them mainly during the daily work commute and during travel (plane, train), so the requiremetns are:
- good sound isolation
- comfortable fit (i.e. either a custom moulded model or a retro-fit custom tip)
- very durable
- detachable and replaceable cord
As I plan to listen to lossless tracks (ipod/iphone - who knows, maybe apple moves to support 24 bit etc on their portables one day :-) ) the requiremetns for sound quality are as follows:
- highest sound quality
- I am not sure if this is "needed", but possibly/likely multiple drivers. Three?
As most likely it will be connected to ipod/iphone I also need:
- certified ipod controls (3-button) - doesn/to have to be integrated, can be optional acessory (like Sure optional cable)
The budget is 'as low as possilbe'. I do not want to spend unnecesserily. But I am prepared to pay for quality and the features I need. The range is 100-1500 GBP.
As I started to look into it I quickly realised that the main problem is lack of possibility to try. And this, togehter with potentially high budget invovled, makes researching things even more critical.
At the moment I am trying to understand which makes and models can fit the requirements. I would appreciate your help in putting together a short list.
So far I see the following:
Make Model Price Custom fit Drivers Cable detach? Connector Full ipod control/mic
Shure se535 gbp360 Optional gbp90 3 yes microcoax Optional cable gbp45
Ultimate Ears Reference usd1000 yes 3 Yes? ? ?
Ultimate Ears 11Pro usd1150 yes 4 Yes? ? ?
Ultimate Ears 18Pro usd1350 yes 6 Yes? ? ?
Ultimate Ears 7pro usd850 yes 3 Yes? ? ?
Ultimate Ears Triple Fi 10 gbp200 Optional gbp90 3 NO ? ?
Westone ES5 gbp1000 yes 5 ? ? ?
Westone ES3 gbp900 yes 3 ? ? ?
Westone ES3x gbp900 yes 3 ? ? ?
ACS T1 gbp600 yes 3 NO ? ?
I need to understand which of these have detachable cords and what connectors they use so I can see which can be fitted with ipod controls if they do not have them natively.
I then need to find ways to audition.
Any advice here?
(I am in London).
