erratik
- Jul 12, 2009
Ya i hear ya and appreciate the advice, but when i tried them out i lost the little bit of control i did have. I'll just wait it out for a month til i get the essense
How would an external DAC affect ingame? I do care marginally more about that than the music side
To be perfectly honest, if you're no longer limited to Newegg, I'd suggest breaking away from Sound Cards, unless you need the higher quality mic-in, or you'll be using some kind of DSP. (IE: If you wanted the Forte's hardware acceleration and CMSS3D and etc, you could get that card and feed a digital out from it to a DAC/Amp, and gain the better quality AND the digital processing.)
Usually, external DACs (such as the previously mentioned Sparrow, or it's big brother, the Audio-GD FUN) preform a lot better than sound cards... I'd highly recommend looking into them, and once again turning your world upsidedown.
Some recommendations sub $300 that would beat the ST/STX:
Audio-GD Sparrow (DAC/Amp)
Audio-GD FUN (DAC/Amp)
Little Dot DAC-I (With a paired, low end Little Dot amp? BEAUTIFUL.)
Used/modded Zero DAC (DAC/Amp)
Audinst HUD-MX1 (DAC/Amp)
